New version of OziExplorer Android Released. V 1.34 Feb 2020
Submitted: Thursday, Feb 27, 2020 at 22:10
The Explorer
For all those OziExplorer die hards...
OziE Android
V 1.34
• Have increased the minimum version of Android supported to remove the message "This app was developed for an older version of Android" (message appears in Android 9 and 10). OziExplorer now supports from Android Version 4.1 upwards.
• Android 10 has forced a new New Device ID method to be developed. The previous Device IDs will still be used where possible for checking the license so old/current licenses should still be valid even though the displayed Device ID is different.
• Supports new permission system for Android 6 and above - permissions are requested at runtime.
• The Last map zoom is now remembered when app is closed and restarted.
• Better visual support for high density screen devices. This means objects such as waypoints and moving map point will now appear larger on high density devices - this can be adjusted in configuration.
• Added support for loading GPX files through screen designer (
new version of screen designer V1.14 required).
• Added ability to download and install OziExplorer update direct from the app (from this version on).
• The state of OziExplorer (last map, odometer values and other on the fly settings) are now saved when changed instead of only saving when exiting the app.
• The Map name in the action bar (title) is now the map name instead of the map file name.
• Removed SMS messaging option from this version (for now anyway).
• Fixed crash which would happen occasionally when rotating device.
• Many other bug fixes.
