Ome shocks
Submitted: Thursday, Mar 05, 2020 at 14:45
ThreadID: 139757 Views:12192 Replies:8 FollowUps:12
Hi all, been a while since I’ve posted.
Wife and I are planning/hoping to drive the ABH and then onto the CSR, heading from the east, and hopefully into the Kimberly area, we have a 10 week time frame.. my concern is the ome nitro charges on our Prado 150 d4d, they have been on the vehicle for approximately 60k, did SW WA, Simpson, Flinders, out back Qld, so they have been around, I noticed the lower shock bushes are looking a little worse for wear, would it be worth doing the bushes, or replace the shocks altogether.. what sort of life span do you get out of them? I really don’t have a clue, thought about replacing the complete unit, and maybe keep as spares, but if they are usually good for 100k/150k maybe I’ll just do the bushes... like to hear your thoughts and or experience in relation to this.. thanks all.. O n Sue
Reply By: Member - mark D18 - Thursday, Mar 05, 2020 at 15:11
Odog .
Replace the worn bushes and keep running the shocks
Good quality shocks should last a least 200 thousand km .
My factory shocks were pretty well worn at 280 thousand km on my HDJ100 , with at least 3 Simpson crossings and numerous outback trips .
I replaced my old shocks with factory shocks , they are very underrated .
I think they are branded Tokica .
You will get a lot of varying opinions , this setup works for me as I am very aware of carting to much weight when travelling solo .
AnswerID: 630320
Follow Up By: Member - Odog - Thursday, Mar 05, 2020 at 15:35
Thanks Mark, yes we have loaded up the Prado on previous trips, last trip it was a two seater, we have a gvm upgrade, for when the van is on the back, but are aware of keeping the weight to a minimum, this trip will be tenting it.. I have heard Old Man Emu, don’t do replacement bushes, and to use EFS bushes...? So will see what I can find.. cheers O
FollowupID: 905669
Follow Up By: RMD - Friday, Mar 06, 2020 at 09:40
I can't imagine any shock lasting to near 280,000km. Although perhaps not leaking they would be ineffective for load control after 100,000km. Just yesterday was in a mate's 100 series and at 221,000kmthe shocks are stuffed. The instant directional control at speed has been lost long ago. It dances on the road requiring constant correction. I had OME yellow on a HJ61 and their good control and bottoming control was gone after 45,000km. Made by Monroe!!!!!!
FollowupID: 905689
Follow Up By: Allan B (Sunshine Coast) - Friday, Mar 06, 2020 at 15:25
RMD, you haven't heard about KONI have you?
FollowupID: 905699
Reply By: RMD - Friday, Mar 06, 2020 at 09:47
Dog.
Being an OME shock it would be good to know who made them. I suspect at 60+ thousand km they will be fairly ineffective if being asked to control a loaded vehicle and also to control suspension and load mass through dips etc, where forces are suddenly tripled. For safety and for relaxed control of the vehicle I would consider replacement. Life of a shock isn't measured in km. It is the use and frequency and severity of control action which determines the life. Just because a shock doesn't leak doesn't mean it is good. I replaced my new Dmax shocks at 5000km from new because they didn't control anything much at all.
AnswerID: 630341
Follow Up By: Member - mark D18 - Friday, Mar 06, 2020 at 14:28
RMD
Last year when I did a Simpson crossing I came across 3 cars heading west to East with either front or back shocks stuffed .
I asked two out of the three if they had replaced the shocks recently and both had replaced shocks with quality after market gear and they were not happy .
I must admit it was the worse East West crossing I had ever done , it was badly chew up on both approaches .
Most of the time it how you drive and don’t overload .
The after market companies must love drivers who replace decent gear after only a few thousand Km .
My Vehicle got across no worries with fresh factory suspension .
FollowupID: 905697
Reply By: Member - Boobook - Friday, Mar 06, 2020 at 09:57
Replace them all and the bushes. It is easier and cheaper to do it now than to do 1 on either of those tracks.
The ABH east of Emu will test any suspension set up. It is relentlessly bone-shaking for around 200kms
Below 20 kmph is slow and just bumpy to the extreme. Above 15kmph is too fast and will destroy your suspension. Even with tyres around 20 - 22 PSI
There is no right speed other than slower is better for the suspension.
I'd be getting Bilstens or Koni too.
AnswerID: 630342
Reply By: Member - Patto (SA) - Friday, Mar 06, 2020 at 10:48
Replace them all and if you have room take the old ones for spares just in case
AnswerID: 630343
Reply By: Ron N - Friday, Mar 06, 2020 at 15:34
Odog, buy some replacement polyurethane shock bushes off eBay, and you'll be right for plenty of trips yet.
Many shock bushes are a standard dimension, just measure yours and check against the one you plan to purchase.
Cheers, Ron.
AnswerID: 630357
Follow Up By: Member - Boobook - Saturday, Mar 07, 2020 at 06:31
Personally, I would not do that. Poly bushes are longer lasting and better for road handling because they are firm. However, their stiffness transfers all the load to the shockers and springs. The shockers are more likely to heat up and fade and the whole failure cycle is more likely.
Get expert advice, but for example, using poly bushes is definitely not recommended in Tvan suspension by Track for this reason. The rubber flexibility is part of the load handling.
I haven't been on the CSR, but the ABH, east of Emu is like nothing you will have experienced. It puts everything to test. The suspension, the tyres, the quality of aftermarket fittings, any mods, the people and even the paintwork LOL. For hundreds of slow, long kms. You will need all the help you can get to get through the ordeal.
Also buy a thermal IR thermometer and point that at the suspension every few hours. Slow or stop when the suspension gets hot.
I got something like this.
It will have lots of uses right now. You can check your friends when they come over. LOL
Apart from that, it is a quick way to check your suspension, tyres, wheel temps and camper.
Hmm, I might get mine out of the toolbox....
FollowupID: 905704
Follow Up By: RMD - Saturday, Mar 07, 2020 at 13:51
Boobook.
Really?
With a Tvan the end of front trailing arms and the ends of the axle arm are rubber similar/same as on LandRover arms. There for flex ability. Nothing to do with shocks at all and they don't transfer loads to the shock either. Not sure what you are getting at? Only the upper and lower end of shocks are taking control forces. They only take the resistance loading which the shock itself creates. I cannot see how poly or rubber would have any effect on shock or any heating other than what normally would be created by the terrain on that particular shocks resistance to movement.
FollowupID: 905713
Follow Up By: Member - rocco2010 - Saturday, Mar 07, 2020 at 14:28
Good tip on the thermal imager Boobook
One of the group on my CSR trip last year had one and after a few days of use we could get a guide to how the shocks were handling the conditions .
Not sure about checking every few hours though. Half an hour on the infamous corrugations around Well 33 had most shocks in the party too hot to touch. That's time to stop. And they seem to cool fairly quickly.
The only issue we had with shocks in that group was a guy who had replaced the rears on his 200 series before the trip and the fitter made a mistake somehow and the top was somehow damaged. He didn't bring the the old ones as spares but some clever guys managed a fix to keep him moving.
FollowupID: 905714
Follow Up By: RMD - Saturday, Mar 07, 2020 at 15:58
Rocco
I don't think Boobook is mentioning a Thermal Imager, only a Laser aimed Infrared digital thermometer. I always carry one or two for same checking. Easy to compare wheel bearings, dragging brakes shoes or seized disc pads etc. Is aimed at bottom of radiator tank immediately you pull up, engine running, you get and idea of what cooling reserve you have or how close to maxxed out of cooling system you are. Good for fridge checking too.
FollowupID: 905716
Follow Up By: Member - Boobook - Saturday, Mar 07, 2020 at 16:11
RMD, there seems to be confusion, I am not talking about the trailing arms. I'm talking about the shocker rubber bushes. They should not be Poly is my point.
rocco2010, I'd like to take credit for the IR thermometer idea, but I got it from here. I think it was either Stephen L, The Landy, or Wildmax, maybe even Mick O
FollowupID: 905717
Follow Up By: RMD - Saturday, Mar 07, 2020 at 18:37
Boobook.
On a T van, Shocker bushes don't take load, they only take forces created by their own resistance to movement, beit on annular bushes or compression rings. I agree the poly will be a little harder bush though.
FollowupID: 905723
Follow Up By: 9900Eagle - Saturday, Mar 07, 2020 at 21:22
RMD, I carry two thermal testers, one left hand and one right hand with 5 fingers one them, sometimes I even use my foot. They work all the time.
Cheap and reliable and they don't need batteries. To date they haven't had any electronic or mechanical failures and have been used for testing bearings, tyres, drivelines and even exhausts temps on jimmys to check injectors for more years than I care to remember. Even use the same hand method with some spit to heat and install bearings on shafts
Ron N. big, big thumbs down from me on poly bushes.
FollowupID: 905724
Follow Up By: Allan B (Sunshine Coast) - Saturday, Mar 07, 2020 at 23:36
Eagle, their proper name is Digital Temperature Indicators. lol
And using your foot is Imperial Fahrenheit measurement units.
FollowupID: 905727
Reply By: Jackolux - Saturday, Mar 07, 2020 at 00:22
Definitely replace the bottom bushes , they will be flogged out and you will break the bottom eye off the shock . I broke 2 on my Hilux before I realised why . I then replaced the bottom bush at regular intervals , no more problems .
It turned out to be a well know problem , google it plenty of info .
I would probably replace the shocks ,
Koni have a shock that you can replace the bottom bush without removing the whole strut .
Here ya go ,
https://www.newhilux.net/phpbb/viewtopic.php?f=28&t=30113e , its simply the bottom bush flogging out and the eye of the shock hitting on the lower control arm , any make of shock will break but being able to replace the bush without having to remove the complete strut is a big plus , look at Koni's .
AnswerID: 630365
Reply By: 9900Eagle - Saturday, Mar 07, 2020 at 09:31
Odog I replaced my ome rear shocks around 100,000k, no weeping but they were on the way out..
The life of a shock depends what has happened to it during their lifetime, so there is no way to say how long it will last. Example, give your vehicle to Toby price to test and se how long they last.
AnswerID: 630368
Reply By: Member - Odog - Saturday, Mar 07, 2020 at 16:56
Thanks everyone, I rang ARB who fitted the suspension, and of course the reply came “ the springs and shocks should be replaced after 60k to 70k” guess they saw me coming... ha..
guess I’ll have a long think about it, and go somewhere reputable to see what they say... thanks again all.. cheers O
AnswerID: 630372
