jurgen caravans
Submitted: Sunday, Mar 08, 2020 at 09:35
ThreadID: 139770 Views:11532 Replies:3 FollowUps:1
Hi all looking at buying a 2012 Jurgen 20 ft van with AL KO IRS suspension . Has anyone had any problems with this set up and can they be upgraded . cheers
Reply By: RMD - Sunday, Mar 08, 2020 at 15:01
Mollyduka
If the van has done a fair bit of work then the rubber suspension will have sagged to a certain extent. Only replacement of the units would restore to OE. I would not buy a van with rubber suspension. Maybe in Europe if I lived there with smooth roads. However, if used anywhere other than smooth roads I would not consider buying a van with that type ofsuspension. Perhaps Alko have better units than those for sale now. The style of frame underneath sort of prevents fitting a decent suspension system.
Edit. I notice IRS is mentioned. Independent Rear Suspension. Independant maybe, but not IRS unless only on the rear axle set. Possibly IRS is being used for description of Independant Rubber Suspension. A bit confusing in motoring terms.
AnswerID: 630389
Follow Up By: Nomadic Navara - Tuesday, Mar 10, 2020 at 23:34
The best off-road vans produced Oz, Pheonix, built by Barry Davidson, used that suspension. They survived extremely well. There is nothing much better produced even today.
FollowupID: 905793
Reply By: Member - abqaiq - Tuesday, Mar 10, 2020 at 11:42
Alignment of independent suspensions (without full cross axle and maybe even with ) is a specialist job. Usually not doable by a typical alignment place as they are setup for a four wheel single frame job (car type system) . I found that truck alignment places have the correct machine to do trailer alignments. Just saying....
AnswerID: 630408
Reply By: Gbc.. - Tuesday, Mar 10, 2020 at 13:45
Any Jurgens which were imported AND meant for offroad had the Alko rubber suspension cut off and had cruisemaster coil trailing arm suspension installed.
AnswerID: 630411
