Van repaires
Submitted: Thursday, Mar 19, 2020 at 20:29
chris a
Good Guys
A little help please
The vinyl on the front of my little van is starting too crack
is their a good out side vinyl paint that I can put over it
Chris
Reply By: Ron N - Thursday, Mar 19, 2020 at 21:10
Chris - What item is made of vinyl on the front of your van? I'm thinking the bumper - but bumpers aren't normally made from vinyl.
Before you try to repair or paint anything that is made from a "plastic", you need to precisely identify the material it's made from, to ensure that you choose the correct product to repair it or paint it.
Cracks need to be glued up prior to painting, and the area sanded back, before any paint is applied.
If you just paint over cracks, they will rapidly reappear.
Cheers, Ron.
630581
Follow Up By: chris a - Friday, Mar 20, 2020 at 08:05
Thanks for the reply Ron
The vinyl material is attach to the front of the van to prevent rocks hitting the front of it.
906043
Follow Up By: RMD - Friday, Mar 20, 2020 at 08:21
Chris. If cracked it cannot be repaired. Replacement? Painting is if no use as above. To good vinyl, people apply Armor All. That is the worst thing to do, it ensures cracking will happen. Although not what the company leads you to believe.
Apply Vaseline/Petroleum Jelly to vinyl as it replaces the lost hydrocarbons from the vinyl. A silicon substance is not good, ever. Vinyl is made from hydrocarbons, Armor All is not.
906045
Follow Up By: Geoff K4 - Friday, Mar 20, 2020 at 10:46
Replace it as RMD said
906049
Follow Up By: Kazza055 - Friday, Mar 20, 2020 at 12:12
Why not replace it with aluminium checker plate either plain or anodised black.
906054
Follow Up By: Ron N - Friday, Mar 20, 2020 at 13:08
Chris - The best advice is already given above - just strip the vinyl off and replace it.
Cheers, Ron.
906056
Follow Up By: chris a - Friday, Mar 20, 2020 at 13:45
YES I think II will do that thanks guys
906062
Follow Up By: 9900Eagle - Friday, Mar 20, 2020 at 17:28
Just have a good think about aluminium, as many a back window on the tow vehicle has been broken by hard aluminium fronted vans.
906072
Reply By: PeterInSa - Friday, Mar 20, 2020 at 22:45
I removed the vinyl from a friends van and installed the Silver version of the Clark Rubber product below, it looked great, helped to sell the van. Its only a meter wide that could be a limiting factor. Not sure whether you can buy a 2.4m length maybe you purchase 3m.
I thought my purchase was wider as I sold the left over to another caravan owner for a similar job.
Cannot recall whether I used the 3mm or 5mm, most likely the 3mm.
https://www.clarkrubber.com.au/collections/auto-caravan-and-camping/products/24186p-checker-plate-matting
630614
Follow Up By: chris a - Tuesday, Mar 24, 2020 at 19:27
Thanks Peter I will have a look at that
Chris
906192
Follow Up By: henpecked - Tuesday, Mar 31, 2020 at 15:19
G'day Peter,
Good solution for my problem.
Did you find it necessary to use glue at all? I'm presuming the rubber is somewhat heavier than the vinyl.
Ted
906412
Follow Up By: PeterInSa - Tuesday, Mar 31, 2020 at 18:00
Did not use Glue, we
Left the vinyl in the sun for a while ( easier to use)
Stapled it at the top
Stapled at the passenger side
Stretched and then stapled at the drivers side
Then stapled the bottom section ( Mate put a staple thru his mobile phone during this effort)
ie its best as a 2 person exercise, one stretches, the other staples.
Then replaced the Top/bottom trims and screwed down the ( previously lifted up) side trims.
906419
Follow Up By: henpecked - Tuesday, Mar 31, 2020 at 20:16
Thanks for the info. Peter.
I will make sure all phones are out of range.
Ted.
906420
