Hilux LN106 suspension plate mount buckled - cause for concern?
Submitted: Wednesday, Jun 03, 2020 at 19:18
ThreadID: 140109 Views:10589 Replies:3 FollowUps:11
Just thought I'd ask for some opinions on this. Just torqued the front u-bolts on the driver's side and noticed afterwards that the perch the u-bolt plate sits up against (on the underside of the axle) is somewhat buckled. I don't think it was buckled before I tightened the bolts. I've attached a photo of the perch.
I only used a regular-sized 22mm ring-spanner (probably under a foot long) and applied a bit of grease to the threads. It's on pretty tight.
Should I be worried....?
Thanks a lot, guys.
David
Reply By: Member - Core420 - Wednesday, Jun 03, 2020 at 19:34
If you applied grease to the threads before tightening you should reduce the make up torque by a third otherwise you will overtighten the nuts and put undue stress on the bolt. Although there is a decent safety factor in the bolt design, I would replace them. However, the buckled plate would place uneven load on the ubolts if you don't fix that first.
AnswerID: 631977
Follow Up By: Frank P (NSW) - Wednesday, Jun 03, 2020 at 21:42
Also, if I'm not mistaken, the bolts look bent. Something not right there.
FollowupID: 908375
Follow Up By: David Y5 - Thursday, Jun 04, 2020 at 06:23
Thanks, Core420 and Frank. I see I'm going to have to do something about it! You're right, the driver's side bolts are bent; they're splayed along the length of the axle. They're EFS, if that makes any difference. The passenger side u-bolts (also EFS) are also bent; however, the ends haven't splayed apart, they've bent away from the axle on both sides. I'm beginning to think they're designed to bend a bit?
A guy below suggested to straighten the perch and pack it with a wedge or something. I think I'll go down this route. Hope it'll hold for a few trips until I get around to fixing it....
David
FollowupID: 908377
Follow Up By: Gbc.. - Thursday, Jun 04, 2020 at 08:21
Check with the manufacturer but any suspension U bolts I've used are to be ditched and replaced once the tension comes back off. Are you missing a backing plate for the perch to spread the load out maybe?
FollowupID: 908381
Follow Up By: Athol W1 - Thursday, Jun 04, 2020 at 08:35
As a now retired Automotive Engineering Tradesman I was taught to never place a nut onto a bolt , or a bolt into a threaded fitting, unless there was some form of lubricant placed on the threaded portion.
This lubricant should preferably be one as specified by the component manufacturer, but in the absence of a manufacturer specification then light grease or light engine oil was sufficient.
In addition to this lubricant the thread must be clean, and the correct torque applied. There are also instances of bolt length being measured and the bolt tightened to achieve a specified amount of bolt stretching, this is often the case with Aircraft applications.
In the case of axle U bolts the correct tension/stretch/clamping load being applied must be greater than the maximum load that will ever be applied during service. Should you find a broken U bolt in service then it was most likely UNDER torqued at original assembly, as the correct stretching of the bolt would have shown up any weakness or flaws in the bolt during assembly.
In the case of axle U bolts it is possible to bend the axle tube (on some vehicles) if the bolts are over torqued/tensioned.
Athol
FollowupID: 908382
Follow Up By: David Y5 - Friday, Jun 05, 2020 at 18:32
Thanks, Gbc.. - I'll be sure to get new u-bolts once I've straightened and reinforced the perch.
Cheers, Athol. I used a very thick, claggy grease (Lanox MX4 Lanolin grease) on the threads. It's pretty damn hard; you have to lever it out with a screw-driver. The consistency is such that if you tried to spoon it out, you'd bend the spoon. Should I use a lighter grease for this application? Always thought that it was a good all round grease. Will be more particular about keeping the threads clean when I install the new u-bolts - thanks for the tip.
The bolts do seem to have stretched - the legs are no longer the same length.
David
FollowupID: 908429
Follow Up By: Athol W1 - Friday, Jun 05, 2020 at 19:50
David.
AS this vehicle is an off road vehicle, and could feasibly be used on a beach at some time, then something like Never Seize (Nickle Coat) or Copper Kote applied to the threads will give the required lubrication AND resistance against corrosion and rust forming within the threaded section (meaning that you will be able to remove the nuts in the future).
DO NOT USE Copper Kote if the vehicle is likely to be used in or near a Coal Mine site, as coal dust and copper sets off a chemical reaction that is not pleasant.
The grease that you are describing sounds like it is intended for the fifth wheel turntables used in heavy road transport.
Athol
FollowupID: 908432
Reply By: RMD - Wednesday, Jun 03, 2020 at 23:22
Looks like the pad was made malformed to me, or the pad material is as soft as butter. The length missing on the inner side is obvious and the pad/perch should be parallel with the axle tube. Also, the bent U bolt would require replacing, it could be straightened if out in the bush but any unseen fracture in the thread will cause grief later.
The pad can be packed with a suitable wedge custom made to make it correct for the lower plate. Made so it cannot work itself out of position. The other side must also be suffering some deformation I would suspect.
AnswerID: 631982
Follow Up By: David Y5 - Thursday, Jun 04, 2020 at 06:36
Thanks, RMD. The perch is a little pitted on one side (I tidied this up and the material is still plenty thick). I like the idea of reinforcing it - the rear axle perches are reinforced with a hard-setting material by the looks of it. I'll do this - cheers.
The other side seems to be okay. There's no perch, the plate simply mounts up against the axle housing. There's only a perch on the drive's side because the diff is in the way.
David
FollowupID: 908378
Reply By: splits - Friday, Jun 05, 2020 at 10:58
I just had a look at my LN106. Your perch is certainly buckled but I don't think anyone could bend it by tightening U bolts, particularly with a ring spanner. It looks more like accident damage or falling down hard onto a rock on a bush track.
I would have the whole axle housing checked and straightened then reassembled with genuine Toyota U bolts tightened to the correct tension with a tension wrench.
Never put grease or oil on any bolts or nuts in a car unless the workshop manual says to do it. It is often specified for some internal engine bolts but rare anywhere else.
Nuts and threads should be clean and dry and the nuts should spin freely. Lubrication used where it is not specified will result in the nut going on too far resulting in overtightening and stretched threads.
AnswerID: 631999
Follow Up By: David Y5 - Friday, Jun 05, 2020 at 19:14
Thanks splits, but I'm very sure the perch wasn't bent off-roading. I spent a lot of time under the Lux installing new leaf springs, and I would have noticed if the perch was bent. I think the fact that the perch is somewhat pitted has weakened it significantly. I incrementally torqued the nuts until they wouldn't budge, by the way - I placed my feet against the wheel to brace myself and really wrenched on them! Read somewhere that they're supposed to be ultra tight, but have second thoughts about this now. Perhaps 90 - 120Nm isn't too hard to achieve with a ring spanner after all.
I'm going to get new u-bolts and reinforce the perch. I used EFS bolts, but will probably try genuine Toyota bolts this time round, as you've suggested.
David
FollowupID: 908430
Follow Up By: splits - Friday, Jun 05, 2020 at 20:44
David. Do yourself and your car's nuts and bolts a favour and get yourself a tension wrench. Keep your feet for walking and running.
At the moment the workshop manual for my 106 is packed away somewhere due to us moving house. I do have the manual though for my LN167. The tension for the rear U bolts is 120 nm. Your front bolts are most likely the same.
I have been using an old $25 second hand Warren and Brown wrench for years on all major bolts and nuts on both of my cars. I had previously used identical wrenches in both the motor industry and the RAAF. A new one cost around $250 at that time.
I took it to a torque calibration company in Sydney and watched them overhaul and adjust it to within 1 psi accuracy.
You may be able to do something like that or you could buy a new one. Whatever you do, make sure you get the a good one.
FollowupID: 908433
Follow Up By: RMD - Monday, Jun 08, 2020 at 20:40
Splits..
Is PSI a torque measurement?
FollowupID: 908470
Follow Up By: Ron N - Saturday, Jun 13, 2020 at 18:13
RMD - I think splits had a bit of a brain fart and meant to write "1 lb/ft". We've all done that.
And torque is measured imperially in "pounds-feet", not "foot-pounds" as many are wont to say.
Cheers, Ron.
FollowupID: 908587
