Buddy Heater
Submitted: Thursday, Jun 11, 2020 at 12:20
Jackolux
Anyone use one of these , I know a lot say they are dangerous
Reply By: Gbc.. - Thursday, Jun 11, 2020 at 12:32
We've used one in the annexe area to warm it up - also have a coleman black cat catalytic gas heater. No chance I'd use one inside, not worth it.
632092
Reply By: Bushranger1 - Thursday, Jun 11, 2020 at 12:33
G'day,
Been using that exact one for years to heat up our permanent onsite van.
Just preheat the van with roof vent open & no one inside. Switch it off when we retire from the campfire to the van.
Stu
632093
Follow Up By: Mark C9 - Thursday, Jun 11, 2020 at 15:41
Trouble with that is that CO is heavier than air, so the bottom of the van (where you sleep) will be low on O2 compared to the roof vent area
Anything that depletes the oxy will eventually kill you.
There are numerous examples of people dying in confined spaces from lack of 02
I remember years ago when a particular Tassie chapter of the cmca advised their members to use the gas cooker to warm up the van.
I did it as
well until we got an urgent email advising to not do it because one of their members died as a result
Apparently we need oxy to survive – who knew
908540
Follow Up By: Bushranger1 - Thursday, Jun 11, 2020 at 16:23
G'day Mark,
Its an old van that has a floor vent (for heavier than air gas) & pretty big vent in the lower portion of the door.
Don't think I would do it in the newer
well sealed vans.
Like I said we never run it when in the van.
Stu
908541
Follow Up By: Mark C9 - Thursday, Jun 11, 2020 at 17:59
OK. just hate to see someone do what I did. I got away with it but many don't
i couldn’t see the difference between using the stove to heat the area and cooking a meal but meals take way less time.
I now use a CO monitor just in case
The other alternative is to head north – this is the 1st winter I've experiences for 20 years.
908542
Follow Up By: Peter_n_Margaret - Thursday, Jun 11, 2020 at 18:13
"Trouble with that is that CO is heavier than air, so the bottom of the van (where you sleep) will be low on O2 compared to the roof vent area"
I have a problem with this...
1. CO is slightly less dense than air, but close enough that it mixes freely.
https://www.google.com.au/search?q=density+of+co&ie=UTF-8&oe=
2. Low levels of oxygen is not the danger. CO is POISONOUS and can kill even with high oxygen levels and low levels of CO. It is an insidious thing. It is not noticed as it takes hold and the effect is to simply doze off, never to wake again.
CO poisoning has become so serious (and so common in the RV community) that it is now illegal to have an enclosed annex on the same side as a gas fridge exhaust. 2 sides of the annex must be open.
908543
Follow Up By: Bushranger1 - Thursday, Jun 11, 2020 at 18:13
G'day Mark,
Camped out on our property adjoining Victoria's Little Desert as we speak. Temp is plummeting & last night was -4 as our
camp is located in a frost hollow.
Very cold walking away from the fire!
Stu
908544
Follow Up By: Mark C9 - Thursday, Jun 11, 2020 at 18:27
Thanks Peter for clarifying that.
My mistake, you’re right of course. I was thinking about my days in OHS when several people died from CO poisoning – old brain cells are dying off too quickly.
I fitted the CO monitor high up on the wall so yes, its lighter.
young fishos died in a van in the same location that I had my van parked in tassie , but they had a genny running near the door
Stu, I love my fire but its too bloody cold to sit around here atm – its down to 18 ??
908546
Follow Up By: Member - J&A&KK - Friday, Jun 12, 2020 at 11:32
For those of you interested in understanding the chemistry of CO poisoning I recommend you read this:
Carbon Monoxide Poisoning:
https://www.rsc.org/Education/Teachers/Resources/Inspirational/resources/2.7.1.pdf
According to the article CO has a 200 times greater affinity with our haemoglobin than oxygen plus impairs the blood from giving up oxygen to cells needing it. So very small concentrations of CO will cause poisoning.
908558
Follow Up By: RMD - Friday, Jun 12, 2020 at 22:31
Mark C9
You mentioned CO is heavier than air, seeing that is the case, why have your CO detector HIGH up on the wall as mentioned? You can be dead before it detects the CO up that far. Isn't it better to have it near floor level so if it is there and above floor you are warned early enough to save the human?
In mechanics pits they have to be vented because of heavy CO filling the pit and killing the tool man.
908569
Follow Up By: Member - J&A&KK - Saturday, Jun 13, 2020 at 11:16
CO is actually about 3% lighter than air at the same temperature and pressure.
Gas Densities
In practical terms this means that the CO mixes easily with air and is likely to be present throughout any column of air that is stirred in any way. Such as you would find in a caravan where people are moving about or a heater is providing convection air currents. That is why CO is such a dangerous gas to red blooded animals.
908572
Reply By: Peter_n_Margaret - Friday, Jun 12, 2020 at 12:28
A diesel heater will do a better job, is a DIY install, costs under $200 and is cheaper to run than gas.
And it will be SAFE.
632112
Follow Up By: Member - J&A&KK - Friday, Jun 12, 2020 at 21:53
We have a Webasto diesel heater in our van. Have run it all night at times when outside temps are negative. Burns about 100ml/hr maybe more but not a lot more. Exhaust is to outside. The
fuel pump makes a bit of noise along with the fan. Very efficient and very safe. Wouldn’t be without it..
908568
Reply By: Jukebox - Friday, Jun 12, 2020 at 17:44
Have one and and an alarm, would I leave it on all night.
No as good warm bed is the way to go.
Warm van at night, and morning.
Check You Tube a guy had one on in his van and a monitored it, all good.
Up to you do the research.
Harry
632115
Follow Up By: Mark C9 - Friday, Jun 12, 2020 at 17:51
just make sure that your life insurance is paid up if you intend to leave it on all night. NOOOOOOO!
908563
Follow Up By: Bushranger1 - Friday, Jun 12, 2020 at 18:01
G'day Harry,
Apart from the risk to ones health it would cost a lot in LPG to run all night!
Diesel heater would be a better option for that as suggested or just a better doona. We are currently camped out in below zero temps & just warm the van before use then switch the heater off. Inside the van is usually around 4 deg but no problem keeping warm under the doona.
Stu
908564
Follow Up By: Jukebox - Wednesday, Jun 17, 2020 at 19:44
Stu
Yep a good doona can do no harm.
And a warm wife helps as
Harry
PS do not go for the morning cuddle on a cold morning.
Can be dangerous.
908672
