Water tank for 98 troopy
Submitted: Thursday, Jun 11, 2020 at 22:30
ThreadID: 140141 Views:10154 Replies:4 FollowUps:2
Hey guys.just got myself a 98 troopy and looking for a underbody poly water tank that goes right up the back of the troopy.
Saw one on another troopy with the right shape to fit but they bought the car like that and no idea where it came from. Only one I've find that's actually suited to the car is a longer ranger one that's $1500, needing something a bit cheaper. Seen some other posts on here but nothing to clear.
Any advice would help Cheers
Reply By: Mick O - Thursday, Jun 11, 2020 at 22:36
60 Litre Water tank. Internal but cheaper than $1500!
AnswerID: 632103
Reply By: Bob Y. - Qld - Friday, Jun 12, 2020 at 05:48
Check out Enmach Industries website here.
They also have an eBay site called Ballistic4x4. Make a variety of shapes & sizes, for both water & diesel.
Bob.
AnswerID: 632106
Reply By: Rod W6 - Friday, Jun 12, 2020 at 10:39
Have you given any thought as to how you are going to get the water out? If its just going to be gravity fed then that means the tap will be lower than the tank or near enough and the tap will always be covered in dust and/or mud... no thanks.
AnswerID: 632109
Follow Up By: Jkempy - Friday, Jun 12, 2020 at 10:50
Was going to run a 12v pump from the solar to a sink inside and also just a tap for whatever
FollowupID: 908557
Follow Up By: RMD - Friday, Jun 12, 2020 at 20:39
Jkempy.
May I suggest, if you fit the tank and the water is valuable/,precious in many cases, you fit a switch controlled 12v solenoid between the tap and tank. A simple switch on, either momentary, is, held on by hand, switch will prevent total loss of water. Just an insurance policy.
FollowupID: 908565
Reply By: andrew t - Monday, Jun 15, 2020 at 09:32
Jump on the troopcarriers of australia facebook page there should be a link to a company call thorburns who make an aluminium one. But there will also be links to others who have done the same as you want to do... Its a troopy only page with a mountain of informations for younto access cdom people who live and breathe troopys
AnswerID: 632158
