Monday, Aug 03, 2020 at 20:04
Not sure how yours is plumbed, but when I had my 100 Series, my Longranger
tank was switched by a switch on the dash, but had its own suction line feeding to the main
fuel pump, it did not feed into the main
tank. Are you sure the switch is actually engaging and switching the feed to the auxiliary
tank, and the wiring plug is still plugged together at the
tank? It happened to
mine, the plug fell out of the socket at the
tank, I had to use cable ties to keep it together.
RMD,
In order to fit the 180 Ltr. Longranger into the space that was occupied by the OEM 45 Ltr.
tank, the spare wheel has to be relocated to a rear carrier on a replacement rear bumper bar. Yes, 270 Ltrs total capacity.
909709
