Article Comment: ExplorOz Traveller
Hi Team, I am wanting to load a GPX file which is a way point list. However, I can't find "how to" in the manual.
Can you please assist.
Reply By: TrevorDavid - Sunday, Nov 01, 2020 at 16:39
G'Day Racey
Page 17 & 48 Or look at the post nine below your post.
TrevorDavid
dontyajustluvit
AnswerID: 633965
Follow Up By: Member - Racey - Monday, Nov 02, 2020 at 08:25
Thanks, I was looking at an outdated manual.
FollowupID: 911081
Reply By: Member - Racey - Monday, Nov 02, 2020 at 08:35
Is 1000 the maximum waypoints that be loaded or the batch limit? I have Camps Australia points in a gpx file I wish to load if possible.
AnswerID: 633971
Follow Up By: ExplorOz Team - Michelle - Monday, Nov 02, 2020 at 12:38
Account limit but please be aware that ExplorOz Places already has 100,000 Places and will probably have the majority if not all of what is in Camps Australia already. Better for you to only upload what you really need or you'll have far too many POIs to manage and you'll just have duplicates causing you unnecessary clutter.
Note that ExplorOz Public Places are avail when using app offline on map and remain interactive offline.
Michelle Martin
Marketing & Customer Support
FollowupID: 911082
Follow Up By: Member - Racey - Monday, Nov 02, 2020 at 14:29
Hi Michelle, thanks for your reply. I was aware that that could possibly happen. I originally created the GPX file to load into ExplorOz, (CE Version) which has served us well over the years. The advantage of the WP's in the GPX file ( approx 8000) is that the Camps Australia site number and name are displayed on the map, which makes navigation very easy. With only 8000 points it will be easy to test and delete if necessary.
Thanks again
Racey
FollowupID: 911086
Follow Up By: ExplorOz Team - Michelle - Monday, Nov 02, 2020 at 16:16
Sorry my answer was wrong. 1000 is the account limit. I'll edit and explain.
Michelle Martin
FollowupID: 911087
