Monday, Apr 19, 2021 at 11:17
Chris,
When, within internet coverage, you create a trek and save it, all the turn by turn instructions - voice and text - are saved with the trek. So, create all your sequential, day-by-day treks as I described above, and save them. Each daily Trek is saved with its own turn-by-turn instruction set.
EDIT: Per Michelle's Follow-Up 913881 below, incorrect info that was here is deleted.
Open the Map Layers window and under Treks, check Personal. This will make ALL your sequential Treks visible on your device. Close the window.
On any given day, click that day's segment, click Goto. The Navigation window will open. Click the green Begin Navigation button.
An icon with a right turn arrow in a white diamond (like a road
sign) will appear at top left. Click it and a drop-down list of turn-by-turn instructions appears. If it doesn't, click the Skip button at top right and the list will appear. (This is because you may not be at the exact starting point of your daily Trek and Traveller is trying to navigate you to it. By clicking Skip, you eliminate that.) When appropriate according to the routing engine's logic, voice instructions will also be issued. (These are also stored in the saved Trek files).
I have just tested this with the Wodonga to
Tallangatta trek I showed above. I put my tablet into Aeroplane mode (no wifi, phone, bluetooth, etc so emulating out in the bush with no internet). It works.
[quote]
What I an trying to achieve is to create a turn by turn track which can be loaded and used without having an internet connection when you start.
[/quote]
I think Traveller does exactly what you want it to do, with the exception of being able to share Treks with your "clients". Once David has worked that out you'll have everything you're after (if I have understood your posts correctly.)
913877
