connecting magellan gps
Submitted: Saturday, Jun 26, 2004 at 22:47
ThreadID: 14164 Views:1817 Replies:6 FollowUps:2
I have a magellan meridian gold gps & toshiba e800 pda and can't get them to talk to each other.
Think I have tried most of the more obvious things such as baud rate etc.
Any clues?
Reply By: Truckster (Vic) - Sunday, Jun 27, 2004 at 00:18
Eric had similar isssues it was the cable.
AnswerID: 65278
Follow Up By: Member Eric - Sunday, Jun 27, 2004 at 12:33
no was the GPS
FollowupID: 326305
Follow Up By: Truckster (Vic) - Sunday, Jun 27, 2004 at 12:52
yea remembered that after I typed it, since you had replaced the cable and all thinkin that it was an issue
FollowupID: 326312
Reply By: matt(nsw) - Sunday, Jun 27, 2004 at 13:48
should'nt be the cable ( I hope). Purchased specific cable from supplynet
AnswerID: 65334
Reply By: Member - Bob - Sunday, Jun 27, 2004 at 17:06
A common cause is to have NMEA turned off on the Magellan. Scroll through the menu and check its on.
AnswerID: 65375
Reply By: matt(nsw) - Sunday, Jun 27, 2004 at 17:47
thanks bob
the nmea is set to v2.1 GSA
baud rate 4800
configuration in oziexplorer ce as follows
com 1
baud 4800
sentence GPGGA
output datumWGS 84
same settings for gps upload/download & obviously magellan selected
gps talks to PC when using oziexplorer without a problem
have tried various combinations, & note some suggestion that com 2 should be selected. This appears to be for infra red!!!
have also tried without success turning the simulator on the gps , both auto & user.
AnswerID: 65386
Reply By: Nicholas from OctaPC - Friday, Jul 02, 2004 at 09:07
Have you asked Magellan? Also what software on the PDA are you using to chat to the GPS?
AnswerID: 66109
Reply By: matt(nsw) - Friday, Jul 02, 2004 at 22:28
Thanks everybody, problem solved.
Turned out to be a wire crossed (literally) in the connecting cable, on the in line pcb board.
Quick solder job this afternoon and now working a treat
AnswerID: 66236
