Gu 4.2 thermostat setting
Submitted: Sunday, Jun 27, 2004 at 10:34
Michael
Hi all, trust you are having a relaxing day, Would anyone know of the top of their heads, what the standard quoted thermostat opening temp is for GU 4.2td. Thanks Michael
Reply By: Jimbo - Sunday, Jun 27, 2004 at 11:05
Michael,
You've probably already tried this, but I'll go on anyway. Put the thermostat in a pot and heat the
water. If it boils and the thermostat doesn't open, it's buggered, buy a new one.
I recently did one on my son's Falcon and tested the new one before installing, from memory it opened at about 80 C. Don't know if diesels are different.
Regards,
Jim.
65311
Follow Up By: Michael - Sunday, Jun 27, 2004 at 11:18
Thanks Jim, but i'm really after the temperature itself.. Best regards Michael
326298
Reply By: Flash - Sunday, Jun 27, 2004 at 14:15
A GQ is 80 degrees Celsius /180 degrees Farenheit.- You can probably assume a GU would be the same I guess.
65339
Follow Up By: Michael - Sunday, Jun 27, 2004 at 15:11
Thank you ,,,
326334
