Teyes APN settings
Submitted: Sunday, Aug 08, 2021 at 07:22
116hynes
I know a few people on this
forum have Teyes android headunit. I have just fitted one to my 79 series Landcruiser. I would appreciate if you have got one with a Telstra SIM if you could tell me what your APN settings are & wether you are getting 4g reception.
Thanks, Kevin
Reply By: ExplorOz Team - Michelle - Sunday, Aug 08, 2021 at 11:35
We get 4g reception in our Teyes SPRO but don't know what you mean by APN settings...ours is an older model but didn't have to setup anything it just worked....sorry can't help with that.
637424
Follow Up By: 116hynes - Sunday, Aug 08, 2021 at 11:44
Thanks. It is in the settings menu, wifi, sim info. Is yours a Telstra SIM?
915513
Follow Up By: Member - Boobook - Monday, Aug 09, 2021 at 08:16
The APN is telstra.internet
But you need to make sure the device is also compatible with the Australian 3G 4G telstra bands or it will not work.
For 3G it is 850 Mhz ( which is closing down in 2023)
For 4G it is 700 Mhz Band 28
915539
Reply By: ExplorOz Team - Michelle - Monday, Aug 09, 2021 at 11:11
Hi Kevin, yes ours is Telstra. Here's some pics. Tap each image to view full screen enlargment and you can read the "caption/description" I've given for each image. There is no setting - just activating the service on/off. These images show me turning it off, then back on. All I did was tap the icons.
Teyes SPRO headunit
Teyes SPRO headunit
Teyes SPRO headunit
Teyes SPRO headunit
Teyes SPRO headunit
[Image cannot be loaded][Image cannot be loaded]
637440
Follow Up By: 116hynes - Monday, Aug 09, 2021 at 11:36
Spro sim
From system menu, bottom right on your screen. This is the menu, select “more”, “mobile network “, “advanced “ scroll down bottom to apn.
915552
Follow Up By: ExplorOz Team - Michelle - Monday, Aug 09, 2021 at 11:55
Ak so I found Access Point Names, if I tap that I get this screen and the first one has a blue dot (selected).
Telstra Internet
915553
Follow Up By: 116hynes - Monday, Aug 09, 2021 at 12:09
If you tap on the the one with the blue dot “telstra Internet” it will give you the APN settings.
915554
Follow Up By: ExplorOz Team - Michelle - Monday, Aug 09, 2021 at 12:15
Yeah I looked at that, nothing significant there. What specifically are you looking for? There was a long list and nothing selected. I can't keep going outside to the car to take more photos sorry.
915555
Follow Up By: 116hynes - Monday, Aug 09, 2021 at 12:43
Thanks, I appreciate what you are doing. Do you mean there are no entries in the APN table? That long list is what I need, so if you do get a chance it would be great, if not I understand. Thanks again for you help & time.
CC3 APN
CC3 SIM2
CC3 sim3
915558
Follow Up By: ExplorOz Team - Michelle - Monday, Aug 09, 2021 at 12:51
Ok after work today, when I head out I'll take more photos for you.
915560
Reply By: 116hynes - Wednesday, Aug 11, 2021 at 21:33
I finally got to the bottom of the problem. Teyes sPro-CC3 family use Band28A, which is only part of the 700mhz spectrum. Telstra uses Band28, which includes Band28A & Band28B. My local
Telstra tower, I am in rural Vic, is using a frequency outside of Band28A, so I was only getting "H+" & no internet. As soon as I got near a tower within Band28A I got full 4G & internet.
637488
