Speed Panel
Hi all, I’m using an iPad mini and have an issue with, when you go into turn by turn mode you loose the bottom of the panel.
Cheers Dennis
Reply By: Frank P (NSW) - Tuesday, Aug 10, 2021 at 22:48
Try:
Menu/Settings/
Scroll down to the red buttons.
Tap Reset Speed.
That should bring it back.
AnswerID: 637468
Follow Up By: TrevorDavid - Wednesday, Aug 11, 2021 at 07:00
Den
In addition to Frank’s advice & with the mini’s smaller screen, you may wish to relocate the panel to a different location on the screen , tap, hold & drag.
TrevorDavid
dontyajustluvit
FollowupID: 915591
Reply By: Member - Dennis M11 - Wednesday, Aug 11, 2021 at 12:51
Thank you both, I found I wasn't holding the panel long enough to be able to move it.
Cheers Dennis
AnswerID: 637476
Reply By: ExplorOz Team - Michelle - Monday, Aug 16, 2021 at 17:40
I just posted a new Tutorial to the YouTube channel that covers the Speed Panel as well as the GPS Lock toolbar - the 2 most important tools you'll see on the map screen.
Michelle Martin
Marketing & Customer Support
AnswerID: 637535
