how to change current position in exploreoz traveller web on mac
Submitted: Friday, Aug 13, 2021 at 16:33
Member - broomecablebeach
The current position with the pulse icon is not my position. How to set my current position? On mac desktop
using chrome browser.
Reply By: kgarn - Friday, Aug 13, 2021 at 22:33
If there is no GPS signal, it is probably showing
Alice Springs !
637508
Reply By: Member - broomecablebeach - Sunday, Aug 15, 2021 at 16:56
Thank's for your message.
I think the desktop / browser version is not working to set your current location on apple mac. It just shows
randomly each day a different current location. On other map apps it works fine.
Hopefully I am not the only person with a mac here.
broomecablebeach
637523
Reply By: Member - Jim S1 - Sunday, Aug 15, 2021 at 18:33
G'day
Broome........
Try this ...... Turn on Location
Services
On your Mac, choose Apple menu > System Preferences, click Security & Privacy, then click Privacy. If the lock at the bottom left is locked , click it to unlock the preference pane. Click Location
Services on the left. Select Enable Location
Services
I just found that my location wasn't showing on my Mac either, so checked on the net. Did the above and now my location is showing.
Then , when you go back to the
EOTOPO maps, click on the symbol in the top right corner.
Hope this works for you.
Jim
637524
Reply By: Member - broomecablebeach - Monday, Aug 16, 2021 at 12:59
Hi Jim,
Thanks for the reply.
I did this all before, also tested it with "find my mac", and the location was working, but still no luck in exploreoz.
Because it is working for you, I had another look at location
services.
I unticked "find my mac", and it was working, showing my current location. Thanks again.
637528
Follow Up By: Member - broomecablebeach - Wednesday, Aug 18, 2021 at 14:39
After next login, current location was wrong again and I was not able to make it showing again correctly.
915654
Reply By: Member - Jim S1 - Wednesday, Aug 18, 2021 at 20:13
Interesting ! I have just turned on my computer after being away for a couple of days and had turned it right off. Checked the map and when I clicked on the "where you are" icon, the correct position came up.
So I don't think I can really can't help any more .
Good luck .......... try giving Michelle and David a go. Use the Help Desk at the bottom of the page.
Jim
637567
