EO Tracker, Combining Tracker Logs possible ?
I have done a 9000km trek around our great nation, what I would like is a basic map showing the journey.
At the moment the journey is split up over 5 different EO tracker logs. Each will show the route for that section. Can a overall map be created from the logs easily?
Reply By: Arebiru S - Friday, Sep 24, 2021 at 19:12
Google map provides a map for the same, where your location is traced, and creates a log for the whole journey.
AnswerID: 638042
Follow Up By: Member - pedro1 - Friday, Sep 24, 2021 at 19:27
I went where Google Maps doesn't go
FollowupID: 916247
Reply By: ExplorOz Team - Michelle - Friday, Sep 24, 2021 at 20:14
Ok so you it sounds like you saved your active tracking periodically throughout your trip hence making separate track logs. So what you can do is use the original source data recorded on the device (rather than the synced data) and recreate one new tracklog. Open the Traveller (or Tracker) app - go to Create Track Log - make sure you do this on the device and in the app that was running during the trip. Select the dates of your trip and this will map all the data that was recorded during the trip in one Track Log for you - plus it will also allow you to view each day in the segment explorer panel.
Michelle Martin
Marketing & Customer Support
AnswerID: 638044
Follow Up By: Member - pedro1 - Friday, Sep 24, 2021 at 21:23
Thanks Michelle for the quick response - Problem solved - Its a brillant feature when used. On my Teyes radio the Create Track Log option wasn't visible till I scrolled to the bottom of the page.
FollowupID: 916250
Reply By: Member - pedro1 - Sunday, Sep 26, 2021 at 14:01
If you follow Michelle's method, the only thing you doen't get, is the option of showing your overnight stops on the map.
AnswerID: 638083
Follow Up By: TrevorDavid - Sunday, Sep 26, 2021 at 17:51
Pedro
Another way is, go to my selection & highlight it, then go to your personal track logs & highlight the five logs that you wish to combine. Make sure you turn on overnight locations. Go back to your map.
Edit.. You will / should get the overnight locations option once the log is saved, not in the create panel. Think they can take a little while to save depending on the size?
TrevorDavid
dontyajustluvit
FollowupID: 916337
