Aussie Batteries GIANT 340AH Lithium Deep Cycle Battery
Has anyone had any experience with GIANT 340AH Lithium Deep Cycle Battery 'Australian Made' from Aussie Batteries. I am thinking of upgrading my AGM as they are cactus. Any thoughts or does someone have 1st hand experience. Any other suggestions on good reasonable priced Lithium batteries.
JR
Reply By: Batt's - Monday, Oct 25, 2021 at 22:47
No experience with their lithium but the giant agm I had was 5kg lighter than the amp tech I ran in line with it they skimp on weight. I have a Renogy 170ah Lithium been good think I got it in March but noticed it's 6kg heavier than the Giant 170ah don't know if that has anything to do with the quality of the battery as far as lithiums go. But If you go Lithium get a charger to suit so it gets charged correctly to get the best out of the battery don't want it failing prematurely.
AnswerID: 638408
Follow Up By: Member - John R (TAS) - Tuesday, Oct 26, 2021 at 09:20
Thanks food for thought
JR
FollowupID: 916815
Reply By: AlbyNSW - Tuesday, Oct 26, 2021 at 08:49
I was about to buy one and thought the 5 year warranty and an Australian company was ticking all the boxes until I read the warranty details
The warranty is replacement in the first year and then a pro rata warranty after that starting at 20% customer contribution in year 2 up to 80% at year 5.
That all sounds fine but the contribution is based on Recommended Retail price which is considerably higher than what they sell their batteries for. In my case I was looking at a 150a/h lithium battery that they are selling for approximately half their proposed RR figure so effectively your warranty is only a couple of years at best because you are effectively buying the battery under warranty.
Sneaky and misleading advertising tactics like that turned me off the company so went looking elsewhere
I couldn’t find any decent reviews on the product to know whether they are worth trying or not
AnswerID: 638410
Follow Up By: Member - John R (TAS) - Tuesday, Oct 26, 2021 at 09:21
Thanks food for thought Yes now read warranty fine print and this sounds dodgy.
JR
FollowupID: 916816
Follow Up By: RMD - Tuesday, Oct 26, 2021 at 12:22
Maybe search who the owner of Aussie batteries is, When they started, etc, It could be a foreign name, or one related to that Ping gentleman. It seems from those who have read the warranty and pro rata's, there is a fair bit of the three B's going on.
FollowupID: 916821
Follow Up By: AlbyNSW - Tuesday, Oct 26, 2021 at 16:36
I spoke to them in Queensland just last week to clarify the warranty details and they confirmed it is correct.
I told them it is a bit dodgy and misleading and will be purchasing elsewhere.
It is a bit disappointing to hear this when you were keen to support a local product,
FollowupID: 916825
Follow Up By: Geoff (Newcastle, NSW) - Monday, Nov 15, 2021 at 17:08
If you are concerned about this battery manufacturers pro-rata warranty it might pay to read a few other battery manufacturers fine print as well.
I've never seen a battery manufacturer offer full replacement warranty outside the initial year. In my experience they are all on the pro-rata model.
Geoff,
FollowupID: 917127
Reply By: RMD - Tuesday, Oct 26, 2021 at 09:02
The advert says they are Australian made, is that everything is Australian made? or we buy the cells and assemble here and call that Australian made. Often done, not sure which way it is.
If Batts comparison shows a 6kg less for a Giant 170 ah lithium over alternatives, that would mean around 12KG less for a Giant 340ah battery compared to other reputable brands. You cannot get Amps Hours out of non existant battery material. Expect less ah in reality and check relative weights with other brands. "AH, COST, WEIGHT" all worth checking.
There is a lithium battery maker in Oz but it isn't Giant brand and so I would suspect the cells are not Aussie at all. Easy to glue the top on a battery after dropping cells into a case.
Best to check and ask questions of the supplier. If they evade, then the answer may be clearer. Aldi has made in Australia claim too, and in small writing, "from less than 10% of local ingredients". They don't even say how much lower than 10% the OZ content is. Perhaps just the packet?
AnswerID: 638411
Follow Up By: Member - John R (TAS) - Tuesday, Oct 26, 2021 at 09:23
Thanks food for thought. Yes I like to support Aussie made but sometimes it hard to work out what what's
JR
FollowupID: 916817
Follow Up By: RMD - Tuesday, Oct 26, 2021 at 10:25
Or in fact what's what!
FollowupID: 916819
Follow Up By: Michael H9 - Tuesday, Oct 26, 2021 at 11:29
Could be what watts too?
FollowupID: 916820
Follow Up By: Member - David M (SA) - Tuesday, Oct 26, 2021 at 13:22
What's Watt's ? Watt's( W) is a unit of power or radiant flux.
Dave.
FollowupID: 916823
Follow Up By: Michael H9 - Tuesday, Oct 26, 2021 at 13:28
You mean electrical power like what might come out of a battery?
FollowupID: 916824
Follow Up By: AlbyNSW - Tuesday, Oct 26, 2021 at 16:38
They confirmed to me that the batteries are assembled here in Australia but of course using imported components
FollowupID: 916826
Follow Up By: RMD - Tuesday, Oct 26, 2021 at 19:41
As I said, Chuck 'em in a box and close the lid. Funny how they are Iighter but as powerful, Right!
Amazing new technology with less internals and 15% more energy dense.
FollowupID: 916827
Reply By: Member - wicket - Tuesday, Oct 26, 2021 at 14:59
Might be worth having a look at these, at least they give you plenty of relevant detail,
https://offroadliving.com.au/collections/12-volt-lithium-battery
AnswerID: 638415
Reply By: Briste - Tuesday, Oct 26, 2021 at 18:11
Another battery option I've stumbled across lately is DCS.
My all time favourite TV commercial was a Telstra ad from the 1980s in which a farmer on the porch gets a call from his now city-slicker son complaining that the car won't start. Not only does the farmer have to tell the son that it sounds like a flat battery, but that it can be found "under the bonnet, son".
Speaking of which, I'm currently doing the rounds of 4WD workhops and auto-electricians getting advice and quotes for installing a second battery in the new Prado. The auto-electrician I saw yesterday, who sells all the usual stuff, put in a strong recommendation for Deep Cycle Systems. This brand, and also itech, claim that they can be installed under the proverbial bonnet. This chap clearly had some experience of them installed thus.
Now I know what *everyone* is going to say about lithium under the bonnet, but does anyone have any actual experience of these two brands performance and durability when installed under the bonnet?
AnswerID: 638417
Follow Up By: RMD - Tuesday, Oct 26, 2021 at 19:52
Briste.
It isn't necessarily the battery brand but the battery type AND where it is in the engine bay, how much radiant heat does it cop for extended periods, or does it operate in a cool/relatively cooler area of the engine bay. Some vehicle cook batteries, others don't, some have NO radiant heat protection some quite insulated and are supplied with fresh cool airflow to negate engine bay heat. Many areas to consider there with any battery installation.
FollowupID: 916828
Follow Up By: Member - LeighW - Wednesday, Oct 27, 2021 at 09:34
I have a DCS extreme under bonnet in my Prado, been there around two years, so far so good still tests
same capacity as delivered.
FollowupID: 916830
Follow Up By: Briste - Friday, Oct 29, 2021 at 09:56
LeighW - I assume your DCS is a second battery? If so, how have you got it wired up to charge? The auto-electrician I spoke with mentioned that a fairly simple charging system was possible. On reflection, I don't recall whether his approach allowed for solar input if stationary for several days. Does yours?
FollowupID: 916859
Follow Up By: Member - LeighW - Friday, Oct 29, 2021 at 10:10
Yep aux battery, is charged directly off the alternator via a VSR.
FollowupID: 916860
Follow Up By: Briste - Friday, Oct 29, 2021 at 10:17
So no solar input I take it?
FollowupID: 916861
Follow Up By: Member - LeighW - Friday, Oct 29, 2021 at 13:03
Solar can be plugged into if required by plugging into the cars anderson plug. Battery can also
be charged by thew caravan solar panels if it is connected to the car.
FollowupID: 916862
Reply By: Member - Bigfish - Tuesday, Oct 26, 2021 at 18:15
I know their AGM 140 AMP only had the weight advertised for 110 amp/hr agms....dodgy as far as I,m concerned.
AnswerID: 638418
Reply By: Peterbilt - Thursday, Oct 28, 2021 at 09:10
I’ve run a Winston Battery LP12V90AH LiFePO4 from EV Works as a second battery under the bonnet in a 90 series diesel Prado since 2014. It’s been a great battery and is now in my 70 series, albeit in the cab. EV Works state that these can be used in place of an ordinary automotive battery. A mate has been using his for even longer so it’s been a good product for both of us.
https://www.evworks.com.au/winston-battery-lp12v90ah-lifepo4-cell-12v-90ah
AnswerID: 638429
Reply By: Member - McLaren3030 - Monday, Nov 01, 2021 at 11:10
Hi John.
If you haven’t already, check out Renogy and Solarking LiFePo4 batteries. Good reviews, and at a reasonable price.
AnswerID: 638460
Reply By: Member - John R (TAS) - Monday, Nov 15, 2021 at 18:41
I ended up taken the plunge with amptron 200 ah × 2 with lithium amptron ac to dc charger and endrive dc to dc and solar. Was convinced to upgrade the charger system didn't trust the just drop in replacement. I use a victron bms to monitor what goes on. Interesting advice was to periodically charge each on its own as that allows all cells to equalis accross both batteries. Wish me luck only time will tell.
Thanks for everyone input much appreciated
JR
AnswerID: 638607
