Wednesday, Nov 10, 2021 at 10:53
RMD,
"The electric vehicle 1300Nm doesn't hang there putting out that torque so it is a bit meaningless. "
Well yes, but once it starts to turn the remaining 1299Nm is mighty handy!
I don't get the point you're trying to make about the Prado. Yes, the Prado uses variable gear ratios AND a modulated right foot to vary the torque delivered. The EV uses only the right foot. Of course it uses amps to create the torque, just as the Prado uses
fuel. Press harder, use more amps, use more
fuel. Either way the
tank empties faster the harder and more often you push the right foot. I don't think we are in disagreement.
" So you believe high amps starts often/always still retains full battery life? "
Not at all, and I didn't say that. I said "Just like if you flog your ICE (Internal Combustion Engine) car off the mark regularly you get increased wear and tear." In an EV that is reflected in the short term in battery SOC and in the long term, battery life. Same as an ICE vehicle, drive moderately and everything will last longer. Again, I doubt that we differ.
Towing:
I simply answered your point that you don't see EVs towing trailers. Now that EVs with a rated towing capacity are coming onto the market, perhaps you will see some loaded with the weekend project going to and from Bunnings or Flower Power. And that will affect the range. But I would say that on average, in suburbia which is where EVs are most appropriate, that will make no difference. You'll still get to Bunnings and back with enough juice to do it again and again. You'll just have to recharge more often.
Highway towing is a different matter. Range is severely affected by towing and until there are more frequent chargers available it is largely impractical except for a few EVs that have exceptional range/battery capacity. Having said that
someone has had a go. It's pretty basic trailer-touring, but as vehicles and batteries improve, so will the options.
As for Albo - I think further discussion about him and his quote would be off topic, so I'll leave it alone.
Re the house battery having insufficient capacity to charge an EV - on average it doesn't need to have the same capacity as the EV battery to give the EV the benefit of stored solar. Statistics show that the average annual driven distance by passenger cars is 14,000km, or 40km a day (rounded up).
Link. That represents about 5kWh out of an average EV's battery - easily replaced by a 10kWh house battery. Of course there will be instances where this won't work, but on average it will. It's already being done in countries that are ahead of us in this area.
I think it is pointless to fixate on the expensive house battery. Energy from renewables is here and increasing. Mass storage of excess energy is in its infancy but is growing, so that charging EVs from stored renewable energy is not just a possibility in the future, it is a certainty and it's not that far away.
917025
