gu patrol sub tank leaking
Submitted: Friday, Jul 02, 2004 at 18:29
ThreadID: 14317 Views:2306 Replies:3 FollowUps:1
The sub tank has crack along one of the seams on my gu gas/petrol patrol and is leaking petrol, in being fixed at the moment under warranty. I have being told that it is not the original tank, is there any way of telling eg. nissan stamp somewhere on tank. Certainly looks bigger then 30 litres.
Cheers Dave
Reply By: Mrs Diamond - Friday, Jul 02, 2004 at 19:39
id be looking at who fitted the lpg.
a lot of times they fitter a bigger sub tank if they have to remove an originall one to fit the gas tank
AnswerID: 66185
Reply By: mygu4500 - Friday, Jul 02, 2004 at 20:05
Previous owner fitted lpg, when I get the patrol back I will run petrol till nearly empty to work out size of tank , I dont think the gauge is accurate.
AnswerID: 66188
Reply By: Member - Roachie SA- Friday, Jul 02, 2004 at 20:41
Dave,
The standard tank will have a cover plate underneath it with several holes of about 40mm diameter in it.....mongrel of an idea as little stones get caught in between it and the tank. The aftermarket tanks that I know of, all have no guard under them and are just a flat bottom surface.
Good luck
AnswerID: 66192
Follow Up By: mygu4500 - Friday, Jul 02, 2004 at 21:06
Got no guard on tank and a flat bottom must be aftermarket, bigger tank greater range (It needs it) yippie!! Now I've just got to work out the size.
Cheers Dave
FollowupID: 327032
