LED 12V switch
Submitted: Monday, Jan 31, 2022 at 19:11
Jerry D
Hi knowledgeable people, need some help please
Im trying to wire 12v pump with LED switch
Dont know how to do it.
I like LED to come on when switch is on & Led off when switch is off.
Tried all different configurations without any luck.
Thank you guys
LED switch
LED
Reply By: Kazza055 - Monday, Jan 31, 2022 at 19:31
Wire +12V to pin 1, pin 2 then goes to the pump but you also link it to the + LED connection and the - goes to the earth. This is assuming that the LED is designed to be used on 12V and it already has a resistor built into the LED part of the switch.
If you need a resistor, 860 ohms in series should be fine, you could put the resister between pin 2 and LED +.
639305
Follow Up By: Jerry D - Monday, Jan 31, 2022 at 19:40
Thanks Kazza,
+12V to pin 1
pin 2 goes to +pump & +LED
-LED goes to earth
Its fiberglass slide on & no earth?
Any solution PLEASE?
918347
Follow Up By: bellony - Monday, Jan 31, 2022 at 21:26
Jerry, in this case Earth = -12V
918349
Follow Up By: Kazza055 - Tuesday, Feb 01, 2022 at 16:02
Here is a diagram of how to wire it assuming the LED has a built in resistor and is designed to work on 12V
LED Switch
918361
Follow Up By: Member - lyndon NT - Tuesday, Feb 01, 2022 at 20:24
Hey Kazza,
your not trying to confuse him with supply and load there are you.
Just stirring the pot
918365
Reply By: Member - wicket - Monday, Jan 31, 2022 at 19:54
Jerry
Youtube is your friend.
639306
Follow Up By: Jerry D - Monday, Jan 31, 2022 at 20:05
Honestly I did try
but all LED switches are 3 pin
918348
Reply By: Greg W22 - Monday, Jan 31, 2022 at 22:52
Your earth wire goes to the dull looking pin. Without earth the led will not work. Then the + wire and wire to the pump goes to the other 2 pins.
639313
