Kroombit Tops NP, Central Qld.
Submitted: Sunday, Feb 06, 2022 at 13:23
Glot
A loverly spot on a warm day. Easy drive in from Calliope. Suitable for normal vehicles however, once you hit the
park boundry, it gets a bit rough but still okay. Due to the narrow roads, not recommended for caravans or campers. You could get away with a small van or camper if you didnt run in to anyone travelling the other way but I wouldnt risk it.
Loverly big grassed campground at Griffirhs
creek. Un designated sites. This is kept mowed by a family of horses. They keep their distance.
No facilities other than some fire pits.
The track to the bomber is closed to vehicles now due to erosion. You can walk it but note the distance. The track to Marble
water hole is getting close to the same condition. Still open but very rough.
Reply By: Frank P (NSW) - Sunday, Feb 06, 2022 at 15:48
Thanks for the update, Glot. I have copied this as a comment to the Kroombit Tops NP place entry. It appears under my name but I have credited you with the info.
If you are a Traveller user you can add your comments like this directly from the app.
639358
Follow Up By: maurice b - Sunday, Feb 06, 2022 at 19:30
I visited the place last year after spending a week in the Expedition NP. A mate and myself entered the
park via the Razorback Spur from Beilba. We were surprised that the developed
campsite had no
toilets . The track into Betsy was reasonable , however the exit was quiet washed out in place and a AWD with low clearance would have struggled . We exited the
park to the south to Cania Gorge . A couple of photo's here
https://photos.app.goo.gl/9kD76CpwnvncJmtFA
918431
Follow Up By: Genny - Sunday, Feb 06, 2022 at 23:18
When exiting the
park to the south, if you turn left, then right at the next
intersection, it takes you down through the old Monal Goldfields. Track from Kroombit down to Monal road can be pretty ordinary, and Monal road has a pretty steep dirt road range that can be pretty ordinary too. Left onto Dooloo Tops road off Monal Road, and just after descending another steep range, you wind up down at the old Glassford
Creek copper refinery. Two 100+ year old chimney's still standing (maybe not for long). Continue on to
Monto -
Many Peaks road. Only the last road is in any way suitable for towing, and there is a steep range on it too.
918433
