XHiRes pack
Submitted: Tuesday, Feb 15, 2022 at 18:21
JTcaf
Can someone please advise the benefit of XHiRes pack? Satellite view nor available offline so looking for more info when in the bush
Reply By: ExplorOz Team - Michelle - Tuesday, Feb 15, 2022 at 19:12
This is the extract of information from the
EOTopo webpage:
WHAT IS THE DIFFERENCE BETWEEN THE LORES, HIRES & XHIRES?
The LoRes pack contains the map data for levels 1-9. HiRes contains map data for levels 9.1-12 but will allow zoom at full resolution to level 18. XHiRes adds the remaining detail for levels 12.1 - 18. This XHiRes pack might be considered optional for those that would prefer to avoid using the additional 2GB of storage that the XHiRes will require. This is personal choice. TIP: the type of map data in the XHiRes include minor fine detail that only appears above Level 12 showing buildings as
well as all "short" roads/tracks including walk paths, bike tracks, bridle
trails, unsealed roads/tracks in both residential and non-residential areas. The definition of "short" refers to 0.001 degree (approximates to 111 metres). Therefore if the road/track is less than 111m at the zoom scale you are viewing, it will not appear unless you have XHiRes map pack installed. It is recommended that if you have the available storage space that you should include the XHiRes download.
639469
Reply By: Member - wicket - Wednesday, Feb 16, 2022 at 08:33
You can view sat maps offline BUT you will have to use google maps, it’s not a particularly effective result though, youtube will give you some tips
639480
Reply By: Frank P (NSW) - Wednesday, Feb 16, 2022 at 11:02
XHires gives you mapping detail down to individual house numbers while off line. You don't get images or satellite view, but you do get a very detailed map.
639487
