Desktop Traveller App Showing wrong GPS position.
Submitted: Wednesday, Feb 23, 2022 at 19:41
ThreadID: 143290 Views:5276 Replies:2 FollowUps:0
When I open the App on the Desktop my GPS position shows as being in Dunsborough some 2000 odd Km away from my real position. Cant figure out how to change it. Advice on how to change it would be appreciated. Thanks, Mark D.
Reply By: Frank P (NSW) - Wednesday, Feb 23, 2022 at 22:21
If it's a Windows desktop, search for Location in the search window and select "Allow apps to access your location".
In the same settings window , under Default Location click the Set default button. A map will come up and you can use it to set your desired default.
If your desktop is not a Windows PC I can't help you other than suggest the process will be something similar.
AnswerID: 639587
Reply By: Member - kimberleybloke - Wednesday, Feb 23, 2022 at 22:54
Thanks Frank, that sorted the problem out.
AnswerID: 639588
