transfer garmin waypoints
Submitted: Saturday, Jul 03, 2004 at 10:14
phil@gero
having trouble transferring waypoints between a dash mounted 128 & a hand held garmin II. can't get them to talk - any clues?
Reply By: ToyMotor - Saturday, Jul 03, 2004 at 10:20
The manuals for the units will explain all - you will need to read them though!
66264
Follow Up By: Member - George (WA) - Saturday, Jul 03, 2004 at 14:09
Check the interface menu, both Garmins have to be on "Garmin to Garmin" interface or similar depending on model
Should work
327097
Reply By: Wazza (Vic) - Saturday, Jul 03, 2004 at 13:08
Does it need to be done GPS to GPS? What about going from the 128 to a laptop and then to the Garmin II.
You can use the program G7ToWin available at:
http://www.gpsinformation.org/ronh/
of course if you are running the two GPS's on the road (or as many do in a comp where nav and driver have their own units) then this method is probrably not for you.
I usually find if two units are not talking to each other, I have the data lines reversed.
66277
