"Red" geofence" circle
Submitted: Wednesday, Mar 09, 2022 at 16:35
Member - Peter H75
Hi all, is it possible to remove the red geofence circle that surrounds the location arrow on the map?
Reply By: Member-George (WA) - Wednesday, Mar 09, 2022 at 17:19
You will find it in "Your Account > Member Profile > My Tracking" the smallest red safety circle is 500 m radius from your home location. As far as I know, you cannot totally remove it. It is there for your safety. Cheers
639776
Reply By: Member - Peter H75 - Wednesday, Mar 09, 2022 at 17:48
Perfect,, thanks.
639778
Reply By: ExplorOz Team - Michelle - Wednesday, Mar 09, 2022 at 17:59
It only surrounds your home address or any other geofence that you setup. You can adjust the radius to zero (0) to remove it. Each Geofence is managed separately. Not sure if you're talking about Tracker or Traveller app as both use Geofences - but if in Traveller go to your User Account and you'll see your Geofences there.
639779
Reply By: Frank P (NSW) - Wednesday, Mar 09, 2022 at 19:44
You can set it to zero if you wish, or any other radius.
Menu/user account/geofences
639782
