Traveller app
Submitted: Wednesday, Apr 06, 2022 at 17:03
Member - Kerry F (WA)
Need help
Want to start a new trek how do you delete the snail trail for the map.
Have saved the map and need to start another trek but can’t work out how to get rid of the snail trail .
Reply By: Frank P (NSW) - Wednesday, Apr 06, 2022 at 17:30
Folded map icon on top right. (This is map layers)
Scroll down to Snail Trail.
Untick the box to take it off the display. Clear to delete it altogether.
640104
Follow Up By: kgarn - Wednesday, Apr 06, 2022 at 21:00
Hi Frank,
According to the manual :
Clearing the Snail Trail does not delete your stored tracking data, just removes the line from the mapscreen."
If that is the case, what is the difference between unticking the snail trail visible box and
clearing the snail trail?
Ken
919166
Follow Up By: TrevorDavid - Thursday, Apr 07, 2022 at 06:08
Hi kgarn
The snail trail only shows you where you have been.
Untucking the box removes it from the map, you won’t see it until you turn it on again. (tick the box)
Clearing the snail trail just clears it from the map but will start up again as soon as you start moving.
Your mapping data is available regardless of whether you have the snail trail on or not.
TrevorDavid
919168
Reply By: Member - Kerry F (WA) - Wednesday, Apr 06, 2022 at 19:10
Tried that still there
640106
Follow Up By: Frank P (NSW) - Wednesday, Apr 06, 2022 at 19:37
I'm not sure we are on the same page because what you say doesn't add up. Maybe what you're trying to delete is no a snail trail. Could it be a Trek? Try unticking the Treks box in the map overlays.
When you say in the opening post you've "saved the map", what do you mean? The map is on yoour device, you don't save that. What actually are you saving?
Not having a go, just trying to help.
919165
Reply By: Member - Kerry F (WA) - Wednesday, Apr 06, 2022 at 21:42
Think I have sorted it out.I went into map layers then in folders it has 1/2 Folders clicked on blue dot with a tick in it and it removed the snail trail
It takes a bit of mucking around to get this app working thanks for your help
640107
Follow Up By: TrevorDavid - Thursday, Apr 07, 2022 at 06:30
Hi Kerry
You were actually looking at a trek / track that you have in a folder. You have two folders, with one of those folders turned on.
What you did is fine but that removes all your folders that are turned on from the map.
To turn on or of individual folders go to map layers. Turn on folders, ( which you have just turned off, circle with the tick in it), then tap on the text right beside the circle. If a folder is highlighted blue, it is turned on. Tap on it to turn it off .
You can see your folders by tapping the search tab directly above the map layers tab. Tapping on the named folder will sow you what you have in them.
TrevorDavid
919169
