Ceiling repair
Submitted: Thursday, Apr 21, 2022 at 07:40
ThreadID: 143586 Views:5520 Replies:2 FollowUps:0
Good morning i need a bit of help with my van ,i have noticed that in the corner of the ceiling of my van the paint is starting to peel so i scraped it all away thinking that i may have a water leak but couldnt see any ,my problem now is how is the best way to repair the ceiling any help would be much appreciated.
Baker
Reply By: Member - McLaren3030 - Thursday, Apr 21, 2022 at 09:13
Hi Baker,
Generally speaking, peeling paint is a sign of either a water leak, or a poorly cleaned surface prior to paint being applied in the first place. Just because you cannot see signs of a water leak in the vicinity of the peeling paint, doesn’t mean that you do not have a leak somewhere else, and the water is tracking and pooling in the area you can see.
As far as a repair to your painted surface, without scraping/sanding away all the paint you will always see the repair. I would suggest you speak with a caravan repairer and ask how they would tackle the problem. However, before undertaking repainting, I would further investigate to determine if you do have a water leak.
AnswerID: 640272
Reply By: humpback - Thursday, Apr 21, 2022 at 16:32
Thank you Macca very much appreciated
Baker
AnswerID: 640274
