Distance between two waypoints
Submitted: Friday, Apr 29, 2022 at 08:11
ThreadID: 143639 Views:6475 Replies:6 FollowUps:5
Is there any easy way in the app to measure the distance between two waypoints.. assume my current position is not one of them.
Reply By: Nomadic Navara - Friday, Apr 29, 2022 at 08:17
What mapping programme are you using?
AnswerID: 640377
Reply By: The Explorer - Friday, Apr 29, 2022 at 08:25
Hi - you may wish to clarify if the distance you are chasing is a straight line between two points (i.e. as the crow flys) or along a road/track between two points (Can't help in either case as not an "app" user - assuming EOTraveller).
AnswerID: 640378
Reply By: Member - Duncan2H - Friday, Apr 29, 2022 at 08:49
Straight line using ExporOz Traveller version 7.1.0
AnswerID: 640380
Reply By: Gbc.. - Friday, Apr 29, 2022 at 09:32
maps/google maps on the phone for terrestrial options.
AnswerID: 640381
Reply By: ExplorOz Team - Michelle - Friday, Apr 29, 2022 at 10:15
Yes of course.. simply select the first waypoint (Place) and tap the green route icon as if setting up a nav plan and then at the top of the nav panel select the mode you want to calculate (straight, driving, cycling, walking) and then select the 2nd waypoint (Place) and tap the green route icon and the system ignores your current location and gives distance (and travel time based on selected mode) between those 2 locations.
Michelle Martin
Marketing & Customer Support
AnswerID: 640382
Follow Up By: 1392 - Friday, Apr 29, 2022 at 16:32
I have a similar issue to Duncan where in some instances when I try to navigate to a waypoint on "Roads unsealed Track" (EOTopo Legend) the navigation path can be via the same designation track but nowhere near the shortest path as viewed on the map. Then to compound my problem, the last section will be 'as the crow flies' and designated as EOTopo legend "Nav clr" not following any shown track.
Example: I have set a waypoint at -31 36 43.27 116 11 4.03 (adjacent to Moondyne rapids picnic ground) and wish to travel from Perth. The route logged takes me via Toodyay road into the Avon Valley NP, along the railway line access road and across the Avon River!
What am I doing wrong? The shortest route is via Chittering Road.
FollowupID: 919453
Follow Up By: ExplorOz Team - Michelle - Friday, Apr 29, 2022 at 20:20
If you know you want to go via Chittering Rd, add a waypoint for that. Here's what I get for your route:
Michelle Martin
FollowupID: 919456
Follow Up By: Member - Duncan2H - Saturday, Apr 30, 2022 at 09:12
Thanks Michelle.. I have that working and after a bit of practice now find it easy to use.
FollowupID: 919458
Reply By: 1392 - Friday, Apr 29, 2022 at 19:48
AnswerID: 640387
Follow Up By: 1392 - Saturday, Apr 30, 2022 at 11:57
Thanks Michelle. Your screen shot only shows how to get part of the way to my desired destination. I had tried putting in multiple waypoints along the route (that I know well) but even then I still cannot get a route that follows the roads that are there. It still leaves me short of my destination with the last section shown as via a straight line through thick scrub (and I assume) by shanks pony!
This is a route that I know. The point of the query is, what about if I am in foreign territory where I do not know the country? Will the navigation ask me to cross rivers where no bridge exists or no cross-over exists? Will it indicate that I have to abandon my vehicle and take to foot?
I can do that without a GPS system and have a history of doing so.
FollowupID: 919459
Follow Up By: 1392 - Wednesday, May 25, 2022 at 13:33
Just received an email update from Exploroz Traveller News and hey presto, an answer to my query. It is a bit cumbersome but works! When all else fails - read the instruction manual!
Auto Routing
If you're already familiar with making nav plans and saving Treks (see User Manual instructions page 19-22), you may have come across times when a section of a track you wish to follow is not auto-routeable. Here's a simple hack to get around the issue:
Change the default MODE from Driving to Cycling then adjust the avg speed to a realistic driving value instead of accepting the provided cycling speed.
FollowupID: 919746
