Current position
Submitted: Monday, May 30, 2022 at 15:22
Member - Kia1
I know this is a simple setting but I am still missing the point.
I am still having a problem getting my laptop to zero in on "My Position" on start up,
and not at "Alice Springs".
Thanks in advance.
Reply By: Member - Dick L - Monday, May 30, 2022 at 15:50
In the User Manual page42
or
On the home screen in the Task Panel click on
the looking glass and type "set default location".
Make sure Location
Services is turned on then scroll down and set your default location on the map.
640714
Reply By: Nomadic Navara - Monday, May 30, 2022 at 16:11
Are you using Windows 11? If so, go to "Settings" > "Privacy & security" > "Location." Make sure you have "Location services" switched on.
Below that there is a section "Let apps access your location." There is a list of apps/programmes that have the ability to access to your computers location. Make sure that the programmes you wish to use your location are switched on.
If you are using another operating system, there will be something similar to switch on your location. Your system will have your location on as the default when the system was installed. Make sure you or someone else has not switched that feature off.
640715
Reply By: Member - wicket - Monday, May 30, 2022 at 16:51
Or you could just read the manual.
640716
