Am I a plane?
Submitted: Thursday, Jun 09, 2022 at 13:07
Member - Simon M13
Hi, recently in a trip to the
Pilbara, using ExplorOz on an iPhone 13, the app continued to revert to a straighline - wanting to fly in a straight line like a plane, when the app was used offline. I'm sure I'm missing something simple - I did search through the options but unable to find a solution. TIA
Reply By: Frank P (NSW) - Thursday, Jun 09, 2022 at 13:20
No, you're not doing anything wrong.
The routing engine that gives you a line following a road or track lives in the cloud and is not available when off line, so when off line Traveller defaults to straight line.
If you want a driveable route you must plan it when you are on line.
640814
Follow Up By: Member - Simon M13 - Thursday, Jun 09, 2022 at 13:26
Thanks Frank. I thought that may be the go - although I was getting frustrated as plans changed and
routes changed due to extensive rains. And with no internet, unable to plan online
919866
Follow Up By: Frank P (NSW) - Thursday, Jun 09, 2022 at 15:00
If you want to approximate a curvey route you can drop a series of pins and create a waypoint at each, then add them sequentially into a nav plan (Trek). The bendier the road the more pins you'll need to approximate the road. If you put all those temporary waypoints into a folder they'll be easier to find and delete later on when you no longer need them.
This is reasonably practical on outback roads which in general are fairly straight.
And PLEASE, if you do this DON'T save the waypoints as ExplorOz (public). Keep them private.
919867
Follow Up By: Member - Duncan2H - Saturday, Jun 11, 2022 at 16:36
Whilst the waypoints approach works its really clumsy.. I wish I could just tap a route out ..
919878
Reply By: Member - Jack - Thursday, Jun 09, 2022 at 14:38
It wants you to 'straighten up and fly right' ! (With thanks to Ray Charles).
640815
