iPhone speed panel disappears
Submitted: Tuesday, Jul 05, 2022 at 09:06
IronBrumby
Hi, I have a iPhone X max and double tapped the speed panel when the phone is in the portrait position and the little "+" to bring it back is not there.
If I rotate the phone to the landscape position it appears no prob, rotate back to the portrait position, and its gone again.
Closed the app and reopened, no luck. change the position from vertical to horizontal in the settings, no luck.
Anyone experienced this and has a remedy?
Reply By: Frank P (NSW) - Tuesday, Jul 05, 2022 at 09:50
I presume you're talking about the Traveller app.
On my Samsung S21 Ultra (Android) it works as it should. Maybe it has something to do with screen size. According to
the table here your phone's screen is 157 x 77.
Mine is 163 x 75. Maybe that 6mm difference in screen real estate makes a difference - David or Michelle may be able to advise if they see this. (They are travelling ATM.)
Do you have the latest version of Traveller installed - 7.3.3?
641061
Reply By: ExplorOz Team - Michelle - Tuesday, Jul 05, 2022 at 11:57
How and why to reset the position of the Speed Panel is covered in the FAQ section of the
ExplorOz Traveller webpage (and yes we're on the road so forgive my lack of more detail finger texting in car). Also covered in the User Manual.
641063
Reply By: Frank P (NSW) - Tuesday, Jul 05, 2022 at 13:02
Following from Michelle's reply above, here's what is in the user manual:
The panel has two defined settings for Portrait & Landscape so you can turn your phone/tablet either way and the panel will adjust position. If you’ve changed the default position of the speed panel however, you may not see it when you go to the other orientation. To fix this, reset the panel back to the default settings by going to Settings – App Resets – select Reset Speed. Then turn the device to the preferred orientation.
641064
Follow Up By: IronBrumby - Tuesday, Jul 05, 2022 at 15:32
Thanks Frank. Reset and now I got my speed panel back - yay!
Appreciate the the fast response from everyone.
920163
Follow Up By: Member - Jim S1 - Tuesday, Jul 05, 2022 at 16:05
That's 100% right Allan, the service from this crew is quite amazing. You just have to ask.
Jim
920164
