Oztent rx5 water pooling
Submitted: Monday, Aug 15, 2022 at 07:30
Konrad R
This isn't common, but in heavy downpour I've had massive
water pooling, I'm guessing that since rx5 has a bigger surface and in a heavy downpour it just starts to accumulate so fast that instead of running off it pools, I had over 4-5 bucket loads of
water pool in there. To oztents credit, I'm impressed that the tent didn't tear or collapse. Has anyone found this problem? Worked out a solid solution?
The only idea I've come up with is using a tarp save like this
https://supapeg.com.au/tarp-saver/ But I really want to avoid having a pole running in the middle of the tent. The attached image shows where the
water pools. A c-clip ridgeline would be ideal but there's nowhere to attach it on the tentside. I know it looks like it needs to be tightened but these images are after the stretch, the tent wat pretty taut, image 2 has
water in it.
Reply By: Richard M29 - Monday, Aug 15, 2022 at 22:08
This would be a thing I would put to Oztent themselves. I am interested in an RV3, so I would guess the same problem could arise. But not having leaking after all that rain, I would be happy either way.
641443
Follow Up By: Bugs - Tuesday, Aug 16, 2022 at 09:58
I have reached out to oztent, they suggested lowering one side of the owning which would work but being the rx not rv and having the front room zipped in this isn’t a good option. I’m not sure this would even be a problem in the rv3, being a smaller surface area you might not run i to this problem and not having the front room, lowering one side would be much easier. Either way this was only a problem in serious downpour.
920577
Reply By: Member - pedro1 - Monday, Aug 15, 2022 at 23:21
Any roof surface that is horizontal has that problem. I use a spare tent pole with a upturned bucket on the end to raise the centre of the roof area when rain is heavy.
That is why caravan awnings also need to be lowered at one end .
641444
Follow Up By: Bugs - Tuesday, Aug 16, 2022 at 10:01
It is a pitched roof, but seems like in heavy rain it doesn’t run of quick enough before the build up sags the material. The bucket would do the trick bit I’m looking for something more long term, especially if the rain get heavy while away from the tent.
920578
Reply By: Member - Bigfish - Tuesday, Aug 16, 2022 at 11:42
Why wouldn't you just lower the front poles temporarily when its raining and if leaving
camp for a long period. Many people have the same issue with vans, campers and tents. Heavy rains sees me lower front poles. Not a big effort really. Or do as suggested...just put a bucket on a pole. .
641445
Follow Up By: Bugs - Tuesday, Aug 16, 2022 at 14:10
If it was just the awning that would be the way to go, the problem is that the rx version has a whole front room zipped in to where the problem area is, you’d have to lower the circled pole and the the whole side wall turns to floppy canvas.
Oztent rx5 pole
920580
Reply By: Member - Bigfish - Tuesday, Aug 16, 2022 at 14:16
Looks like the bucket method might have to be the answer. Hopefully someone who actually owns one and has had this issue may help. Have you tried other
camping forums . Here are links to 2 facebook forums specifically for Oztent.
for oztent more
641446
Follow Up By: Bugs - Tuesday, Aug 16, 2022 at 14:32
Not a bad idea, I don’t have an FB account but definitely worth looking into it, thanks for the links.
920581
Reply By: nickb - Tuesday, Aug 16, 2022 at 19:59
I had similar issues in my old camper trailer. My solution was a spreader bar between the 2 poles - the type with a “c” clip on both ends.
Something like this
https://www.google.com.au/shopping/product/11618933212377337106?lsf=seller:394105196,store:561444437175728963,lsfqd:0&prds=oid:4035786082919124686&q=tent+poles+%26+stakes&hl=en-AU&ei=KWr7YvXMBanq3LUPxcW1QA&lsft=gclid:Cj0KCQjwgO2XBhCaARIsANrW2X0ZkAgg6It0FhxwB3nDLNB46_pArk8F5t39uBv9tiuuIE2prYnATfcaAjcqEALw_wcB
641448
Follow Up By: Shane M11 - Wednesday, Aug 17, 2022 at 10:16
This with a pool noodle slippped over the bar should work.
920593
Follow Up By: Bazooka - Wednesday, Aug 17, 2022 at 14:28
Was thinking along the same lines Nick. I've seen curved poles like that previously. Looking at the photo the Oztent doesn't appear to have lateral poles to hook it on though.
920596
Reply By: Member - McLaren3030 - Friday, Aug 26, 2022 at 09:32
Hi Konrad,
I have an RV4 with side and front awning walls, (not an RX), and it comes with ridge poles that fit across the middle of the tent between the two side poles. You could try an extra ridge pole and side poles and fit them at the front of the main tent to give extra support for the awning roof.
641503
