Improve fuel consumption
Submitted: Tuesday, Nov 29, 2022 at 23:38
Brian J10
Thinking of putting a solar panel on roof of my TojoHJ61.but at an angle , theory that it will create a slipstream when towing the caravan thereby improving the economy ?? Has anyone done this and what were the resuls please ??
Reply By: Member - Core420 - Wednesday, Nov 30, 2022 at 09:27
In theory with laminar air flow it could work. But in reality with turbulent air flow it won't work. Especially given the distance between the panel and the caravan.
I have a rooftop tent and I installed a solar panel in front of it at an angle, similar to your idea. However there's no discernible improvement in
fuel economy. The reason I did it is that I
park the vehicle facing the sun when setting up
camp and the angle improves the panel's performance.
642205
Reply By: Member - Bigfish - Wednesday, Nov 30, 2022 at 10:39
HJ6I is basically a brick. There wont be much you can do to improve
fuel consumption. The panel will make no difference...will help your batteries though.
642206
Follow Up By: PeterInSa - Wednesday, Nov 30, 2022 at 11:45
Have a HJ61Turbo, last of, with the twin headlights. Have an 80w panel on the roof driving the aux battery. Panel is 70cm back from the windscreen and 7cm up from the roof. To me very little noise.
921690
Reply By: Member - AndrewM (NSW) - Wednesday, Nov 30, 2022 at 11:14
I fitted 2 solar panels flat between racks on my Patrol. This resulted in significantly increased wind noise and vibration. I then fitted a "Wind Fairing", similar to Front runners slimline rack, but without the rubber strip. Worked a treat. I believe the main cause of the wind noise is the "cup effect" formed by the solar panel frame. I thought about putting an infill on the back of the panel, but you need to dissipate the heat.
Regards, Andrew
642207
Reply By: Kazza055 - Wednesday, Nov 30, 2022 at 14:10
I fitted 2 x cross bars on the cab rails and found they added about 1L/100km to my
fuel use. I then fitted 2 panels, one on the cab, other on canopy which added about another 1L/100km.
Just part of the cost of running a car decked out with all you extras for towing and touring.
642211
Reply By: Member - John - Saturday, Dec 03, 2022 at 11:57
Have a look at the Stealth Deflector, maybe mount as described in the videos, may make a difference.
Stealth Deflector
642223
Follow Up By: Allan B (Sunshine Coast) - Sunday, Dec 04, 2022 at 12:51
Are these things marketed by Hiclone?
921712
Reply By: Member - McLaren3030 - Sunday, Dec 04, 2022 at 07:03
Whilst I am not an aeronautical engineer, and by no means an expert on most things, from my perspective, “wind deflectors” can do three things. They can push air up an over something more smoothly, but they can also create drag and downforce. That is why on a formula one car, they utilise a “drag reduction system” that opens the rear wing when travelling in a straight line.
Too much angle will create “drag” and may have the reverse effect on
fuel economy, even with the van in tow. Yes, there are wind deflectors on the market, how much they actually save on
fuel economy, I am not sure.
642227
Reply By: Batt's - Monday, Dec 05, 2022 at 17:07
Pop Top caravan way less drag
642244
Reply By: Brian J10 - Friday, Dec 16, 2022 at 23:01
Thanks everyone for input
642331
