Gas Certificate
Submitted: Tuesday, Dec 13, 2022 at 15:11
ThreadID: 145118 Views:4382 Replies:3 FollowUps:0
Hi Guys, All new to this. Have just bought a 2nd hand caravan no Gas Cert or Road Worthy. Passed roadworthy but for the Gas Cert I need to seal behind the fridge as light coming through. Inspector just said tape and seal but didn't really explain. Does anyone have any insight. Much appreciated. Thanks in advance
Reply By: Peter_n_Margaret - Tuesday, Dec 13, 2022 at 15:58
Any leak can allow carbon monoxide from the burner to leak into the living area.
Carbon monoxide is deadly. It kills.
Treat the problem seriously.
AnswerID: 642296
Reply By: Nomadic Navara - Wednesday, Dec 14, 2022 at 08:38
"I need to seal behind the fridge as light coming through."
The light is coming through where? Please give a detailed description of the situation so we can can give you a sensible answer. The model number of the fridge will assist as well as not all the fridges are installed the same way. I refuse to comment on the info you supplied in case I gave you some bum info.
AnswerID: 642301
Reply By: Rangiephil - Thursday, Dec 15, 2022 at 17:54
An easy way to seal is to use flashing tape available from Bunnings. The glue on that stuff is legendary.
I have fully sealed my fridge back for insulation , so that no heat from the coils goes down the sides of the fridge.
AnswerID: 642321
