Offline gps maps
Submitted: Thursday, Dec 29, 2022 at 14:39
ThreadID: 145164 Views:5183 Replies:7 FollowUps:4
Hey everyone,
I am looking for a gps offline map app for WA that is compatible with android auto
I can't find anything on the net, can anyone tell me if there is such a thing
TIA
Reply By: Michael H9 - Thursday, Dec 29, 2022 at 15:52
I believe OSMAnd is Android auto compatible.
AnswerID: 642408
Reply By: noggins - Thursday, Dec 29, 2022 at 19:16
I've used Sygic Pro. in my Samsung Tab A
Has offline maps as well
AnswerID: 642410
Follow Up By: Riff - Thursday, Dec 29, 2022 at 19:29
Im looking for a app to use with Android Auto
FollowupID: 921964
Reply By: Member - Boobook - Friday, Dec 30, 2022 at 09:10
I've tried a few offline maps for android auto and the only one that seems to work properly is Google Maps.
You can download the maps to be offline quite easily and effectively.
How to downlaod offline maps for Google Maps
AnswerID: 642419
Follow Up By: Member - silkwood - Friday, Dec 30, 2022 at 12:07
Second the Google Maps option. It is surprisingly good in many remote areas. Just don't believe the travel times or take its advice on route guidance outback!??
FollowupID: 921969
Reply By: Briste - Friday, Dec 30, 2022 at 09:27
Gaia has an Android Auto app, but you have to have an annual subscription to get offline maps. I was under-whelmed by it, it's hard to read in AA, and the Australian maps are pretty basic. It's a US-centric app. But it works.
AnswerID: 642420
Follow Up By: Member - Boobook - Friday, Dec 30, 2022 at 12:12
Unfortunately I had high hopes and payed for it. It is a waste of time, storage and money.
It is ok on the phone but pretty unusable on Android Auto. You cant change the address or any parameters. You have to disconnect, set up a new route then reconnect to Android auto.
1/10
FollowupID: 921970
Follow Up By: Briste - Friday, Dec 30, 2022 at 14:28
I hadn't bothered to try it for route planning, just a visual check of where I am and what's ahead. Stephan Fischer did a highly critical review of Gaia. His main complaint also was that it's hard to read. That was the app version rather than on AA, I think it's worse on AA.
FollowupID: 921972
Reply By: Member - Cuppa - Friday, Dec 30, 2022 at 14:09
Have a look at Avenza. I don't have extensive experience with it, but needed to download it recently to use a map sent to me to find some specific GPS located trees in the rainforest (part of a scientific survey). No phone signal in the area so needed the maps to be offline. It was so easy, I had a satellite image of the area where the trees were, with each tree marked as a POI so could see them on the screen, together with my position. I think Avenza has lots of free maps, but also some you have to pay to download. The app itself is a free download , so worth having a look. The maps I've seen have been large scale suitable for walking/hiking, & would require downloading a lot of smaller areas to make up WA, but they may have smaller scale maps of larger areas??
AnswerID: 642427
Reply By: Rocket Rod - Friday, Dec 30, 2022 at 15:41
If you want offline 4wd app then look at OziExplorer or ExplorOZ but neither will work with Android Auto. If you're after street navigation outside mobile range, then look at Here Maps as you can download all of Australia in one map. Better than the Google maps way of doing things.
AnswerID: 642428
Reply By: stella j - Friday, Dec 30, 2022 at 21:12
This post has been read by the moderation team and has been moderated due to a breach of The Advertising/Self-Promotion Rule .
Forum Moderation Team
AnswerID: 642434
