Removing etopo21 from device
Submitted: Saturday, Mar 25, 2023 at 17:40
ThreadID: 145465 Views:2478 Replies:3 FollowUps:1
Can anyone help me on how to remove Etopo 21 from an apple iPad mini, I have etopo 23, both map packs take up to much space.
Cheers Dennis
Reply By: Member - Warren H - Saturday, Mar 25, 2023 at 18:18
Data manager, 'clear maps' button at the bottom of the panel.
NT Pajero
2007 Goldstream Crown
AnswerID: 643166
Follow Up By: TrevorDavid - Saturday, Mar 25, 2023 at 20:55
Probably too late, but the clear maps button will delete all your maps including your freshly loaded EOtopo 2023 maps.
Before you load the 2023 maps. Clear maps is the better way to remove unwanted maps, but if you have loaded 2023 mapping already & then want to remove earlier versions, go to Data Manager, directly below the 2023 maps is the others, you will see a blue line with 2021, 2019 etc if you still have them. Tap on the line (maps) you wish delete, and delete them a pack at a time. Saves needing to download the 2023 maps again.
TrevorDavid
dontyajustluvit
FollowupID: 922827
Reply By: Member - Dennis M11 - Saturday, Mar 25, 2023 at 18:51
Thanks for that.
AnswerID: 643167
Reply By: Member - peter g28 - Tuesday, Mar 28, 2023 at 21:10
I came across this issue when I deleted the Topo 21 maps from my iPad and installed the Topo 23 maps.The amount of data the topo 23 maps should take up on a device is about 8.5 gig as shown in Data Manager but in my case the topo 23 maps were taking up 13gig on my iPad when I first installed the complete Topo 23 package.
This meant somewhere in the software the topo 21 maps had not been completely deleted even after I had deleted them to free up..somewhere 6gig was being retained..it had to be gone as I was getting "space error messages" when I was trying to install the complete Topo 23 map package.
It can be a pain for users who have "limited storage space" on the iPad...my has 32gig.
So to resolve this I did a complete uninstall of the Traveller App on the iPad and confirmed this by checking the iPad "systems" storage, to see that the Traveller App was no longer on the iPad, yes, a PIA..but in my particular situation, it was necessary.
Then I did a re instal of the Traveller App (found in the App Store under my previous purchases) and then appropriate Topo 23 packages.
When the full reinstall was completed the Topo 23 Data Manager showed space of the full package was 8.5 gig and not the 13gig as before.
Problem solved.
AnswerID: 643197
