GX 200 series aircon
Submitted: Monday, Apr 24, 2023 at 22:12
ThreadID: 145568 Views:2749 Replies:6 FollowUps:0
G'day all, I have a 2014 GX 200 series. The mode of the aircon seems confused. When it's set on the vents from the dash, the aircon comes out from the dash and on the feet. Does anyone know what the fix or where to look might be.
Reply By: Gary T7 - Tuesday, Apr 25, 2023 at 13:55
I would do a code check first and see if any codes in the system. The system I assume would work with electronic servo motors for direction of the air flow .
AnswerID: 643411
Reply By: Tom N3 - Tuesday, Apr 25, 2023 at 15:47
Thanks Gary
AnswerID: 643412
Reply By: IvanTheTerrible - Tuesday, Apr 25, 2023 at 15:52
Vent position is done on multiple shafts on the heater box. I may be one of the connection to a flap may have come off or the rod from the servo has jumped
AnswerID: 643413
Reply By: Member - DOZER - Wednesday, Apr 26, 2023 at 09:43
Yes, each flap has a servo, there is a way of resetting the system, but its been lost to lcool.org demise...from memory press and hold ac button and recycle button whilst turning ignition on
AnswerID: 643419
Reply By: Member - McLaren3030 - Thursday, Apr 27, 2023 at 07:46
Hi Tom,
My first choice would be to look in the owners manual for the operation of the Airconn. I have a GX, and you can set the air flow to Demisting for windscreen, or face and feet vents.
EDIT, my GX is an MY17, so might be different, however there are about 6 different “mode” settings, plus the dedicated front demister button.
AnswerID: 643430
Reply By: Member - Boobook - Thursday, Apr 27, 2023 at 08:58
Have you ever removed the rear inner quarter panel? I did and forgot to replace a plug for a sensor that goes into it. It played havoc with the aircon, but that was a VX
AnswerID: 643432
