Starlink RV
Submitted: Tuesday, Apr 25, 2023 at 13:29
Peter B85
Hi all,
I am interested in reading RV travellers experiences with Startlink RV, while travelling
Cairns to
Perth, Great Aust Bight, Nullarbor Plains, the Flinders Rangers or anywhere in between.
Peter.
Reply By: Briste - Tuesday, Apr 25, 2023 at 18:26
I thought that this was a reasonable, balanced review after 12 months on the road, provided you skip the bit at the end promoting the flat out multi reel:
https://youtu.be/KDqp8b8eGMo
SL works
well, provided that you have a reasonably clear view south. You still need a phone with data for those times when you don't.
643416
Reply By: Dusta - Tuesday, Apr 25, 2023 at 22:34
i have starlink rv for work . Use it all over the state of WA. Never missed a beat .
643418
Reply By: Pepper - Wednesday, Apr 26, 2023 at 11:12
have seen it in use in my travels , seems very good as usual needs clear view of the sky and clouds / storms limit its effectiveness , uses similar power to a 200litre 12v fridge . cost can be a consideration ..
Hard to prevent the dish being stolen ..
643420
Follow Up By: Member - LeighW - Wednesday, Apr 26, 2023 at 12:35
Stolen dish won't be anygood to another as it is registered to the user.
923057
Reply By: Member - Cant wait - Wednesday, Apr 26, 2023 at 11:54
I’ve had it for several mths and have used it at most camps I’ve been to.
It is very good, but does drop out regularly for a second or two but I don’t even notice it.
Ive even set it up with 30m high trees nearby with filtered
views between the trees but it still worked
Apparently, gamers find this annoying but I can’t tell it has dropped out unless I check on the stats
643421
