dpchip help 1hd-fte installation
Submitted: Monday, Jul 03, 2023 at 20:33
ThreadID: 145942 Views:2969 Replies:2 FollowUps:0
Hello all picked up second hand dpchip for 1hd-fte cruiser was previously spliced into harness has 4 wires brown grey red white...any help on where they go would be great..dpchip themselves don't support second hand units...I presume power red earth brown grey throttle control white injector pump but which one's...thanks in advance...
Reply By: Member - Racey - Tuesday, Jul 04, 2023 at 10:06
Risky business buying 2nd hand unless you have some sort of guarantee and know the connections. Especially knowing it is suitable for your vehicle.
Racey
AnswerID: 644041
Reply By: Andrew L - Tuesday, Jul 04, 2023 at 13:56
Kenny,the reason they have plugs is so you can remove them easily when they play up,
DP are known to set off lights on the dash. It will be a signal interupt for the fuel pressure, either spill valve or similar, 2 in, 2 out.
Suggest you find a dp chip and photograph the wiring colours
AnswerID: 644043
