Calcium in water
Submitted: Monday, Jul 10, 2023 at 22:29
Batt's
Just started looking at what's on the market to reduce calcium and whatever else causes build up in the house
water supplied to our house. We live in town there seems to be excesive build up shower head etc. Looked up Carefree
water conditioners so far but does anyone have something they have been using that works.
Reply By: Matthew G3 - Tuesday, Jul 11, 2023 at 09:42
Hi Batt`s
Have you looked into Hydrosmart, they claim to deal with this on small and big scale.
Matt
644097
Follow Up By: Member - 2208mate - Tuesday, Jul 11, 2023 at 10:08
That works
well but doesn't enable you to store the
water before it resumes it's original state, if I got that right...
924003
Follow Up By: Batt's - Tuesday, Jul 11, 2023 at 13:31
I'll look up Hydrosmart.
Not storing
water in a
tank just normal household use. Have either of you tried any of them mainly wondering if they do what they actually claim. Thanks
924005
Follow Up By: Matthew G3 - Tuesday, Jul 11, 2023 at 16:00
Hi Batt`s
I haven't used it. It came up when i was looking around as my ground
water is only 8 feet down {and hardly any flow} and very salty.
Matt
924010
Reply By: Happy Explorer - Tuesday, Jul 11, 2023 at 19:35
Hi Batt's
I would start with a
water analyse. Your local council can probably do that for you. You may find your problem is much more complex than simply calcium.
Our town
water is mostly sourced from underground and not the greatest quality. I got a sample tested because I have been having a lot of problems at work with buildup of white scale in appliances that heat
water like urns, coffee machines, dishwashers, hotwater systems etc. Also problems in cold
water appliances like ice makers and
water drinking fountains etc. as
well as the usual build up around tap outlets and in shower cubicles.
Turns out that there was very little calcium but rather a cocktail of all sorts of other impurities that will be much harder to deal with. Will need some fairly sophisticated (read expensive) point of entry treatment as
well as polishing filters on each appliance apparently.
Hope that is of some help.
Roy G.
644103
Follow Up By: Member - William B - Monday, Jul 24, 2023 at 12:15
Just a left field reply.
I home brew and use the
water profile from the
water supplier and use that as a basis to treat my
water with chemicals to achieve a
water profile to suite the style of beer I'm brewing.
Try the
water authority or seek out a local brewer or brewing supply company for info.
William
924171
Reply By: Member - Warren H - Tuesday, Jul 11, 2023 at 19:43
The solution will depend on what you want to use it for. State agriculture departments often have useful information. For example if you are using it in the laundry, sodium carbonate aka washing soda will help. There are guidelines for
drinking water quality that will tell you if it is fit for human consumption. Ion exchange cartridges or a reverse osmosis system will remove it, but at an ongoing cost. One thing to keep in mind is that it is dissolved in the
water so it can't be physically filtered out despite what the glossy brochures might claim.
644104
Reply By: Bob Y. - Qld - Wednesday, Jul 12, 2023 at 07:52
Batts,
When I was doing linehaul work, I used to spend 2 nights per week at the
Barkly Homestead, waiting for the truck from
Darwin to arrive the next morning. Often there’d be a heap of bags at the base of the overhead storage
tank, waiting to be added to the
water supply. I did check what it was, but have since forgotten what chemical it was. The
water there was from a sub-artesian acquirer. Maybe you could ring them? 08 8964 4549
Water in
Winton comes from a 4,000’ deep
bore, and is a cocktail of various minerals & salts. Few people in town, if any, do any treatment to their supplies, but build up on shower roses, taps & the like is very gradual. Lawns don’t suffer from an over abundance of chemicals.
644105
