Hells Gate area road update
Submitted: Tuesday, Jul 11, 2023 at 09:20
ThreadID: 145975 Views:4431 Replies:5 FollowUps:1
After some current road information thru to Borroloola if anyone has travelled this recently. We are considering towing our 4WD and tandem axle caravan this way. Thanks, Richie,
Reply By: Member - Warrie (NSW) - Tuesday, Jul 11, 2023 at 13:46
Go into Places, start at Hells Gate and follow the road west, clicking on each place. Most will have pix of the creek crossings and road corrugations. We did it in May last year. Assuming that grading is done at same time after the Wet then July is 2 months later so the road will be a little more worse for wear but it is not heavily trafficked. We met some who said they would only travel it a 40 kmh. A slow trip but they would get thru OK. Also the Trek Savannah Way may help.
Warrie
AnswerID: 644099
Follow Up By: Member - Dick L - Tuesday, Jul 11, 2023 at 14:52
High clearance vehicle only on Qld side
Main Roads Qld
FollowupID: 924008
Reply By: mynance - Friday, Jul 14, 2023 at 19:16
Came through Borroloola to Burketown through Hells Gate 3 weeks ago, Qld side was much better than NT
NT was extremely rough and corrugated actually lost the spare off the back of our van between Seven Emu station turn off and Hells Gate
Myles
AnswerID: 644111
Reply By: Richard C27 - Friday, Jul 14, 2023 at 21:33
Thanks all for the replies, will still consider this travel part. If so, will keep an eye out for the spare, hopefully we have far more luck.
Thanks, Richie.
AnswerID: 644112
Reply By: Craig & Maria - Wednesday, Jul 19, 2023 at 06:35
Agree with myance. Went though 2 weeks ago. Bloody rough first 50km out of Borroloola. Make sure you reduc tyre pressures and take it easy even in the good part as you still come across dips and pot holes.
All for 50 to 60km/h trip if towing. I went trough with 19ft van
AnswerID: 644138
Reply By: Richard C27 - Friday, Jul 21, 2023 at 14:33
Update: just completed this part and all good, as advised reduce tyre pressures and drive to the conditions. 350mm water at Gregory River crossing, all the other creeks, rivers well below this and no problems. The last 100kms or so into Borroloola pretty corrugated, otherwise all ok.
Thanks for the replies, Richie.
AnswerID: 644166
