World energy crisis solved, latest add
Submitted: Tuesday, Aug 15, 2023 at 14:00
ThreadID: 146108 Views:4094 Replies:4 FollowUps:2
Portable 200-400W Car Van Boat Caravan Camper Solar Panel Battery Charger Kit
400W Solar Panel
400W 18V Solar Panel Kit Boat Car Portable Battery Charger for Outdoors with 40A/100A Solar Controller
Feature:
1.Wide Use: It has a single crystal r chip, lightweight and portable, suitable for outdoor travels. Can charge automobiles, boats, motorcycles, electric fans, emergency lights, solar water pumps, RV batteries or any 12V lead acid battery.
2.Dual USB Output Ports: The back junction box has dual USB ports that can charge two USB devices fast at the same time. The solar panel can charge your phone in emergency.
3.High Charge Efficiency: The solar panel with high conversion rate of 24% charges fast in the direct strong sunlight.
4.Stable and Durable: Scratch resistant, non-foaming and easy to clean. Using advanced polyethylene coating technology, its surface is plated with dark blue reflective film, which is uniform and beautiful in color.
5.Adjustable Angle: With a semi-flexible design, the solar panel can bent appropriately to suit a wider range of applications.
Specification:
Type: Solar Panel
Weight: 740g
Conversion Rate: 24%
Panel: Monocrystalline Silicon
Maximum Power (Pmax): 400W
Operating Voltage of The Solar Panel: 18V
Open Circuit Voltage of The Solar Panel: 20V
Output Current: 1600 (mA)
Maximum Power Current (Imp): 1.38A
Output: USB 5V, DC 18V
Short Circuit Current: 1.5A
Irradiance: 1000W/?
Waterproof Grade: IP65
Package Included:
1 * Solar Panel
4 * Sucking Cup
1 * Car Charger
1 * Battery Clip
2 * Carabiner
1 * Solar Controller
1 * 10-in-1 Charging Cable
1 * User Manual
Reply By: Zippo - Tuesday, Aug 15, 2023 at 15:13
These must be the latest "Chinese Watts". The V and A figures wouldn't even get 40 Watts.
1 Sol = 1000w/m2 so that panel size (which is gross, including frame) sees 117.6 Watts. Allow their generous 24% efficiency and the panel would produce 28.2 Watts @ 25C panel temp.
Just saying.
AnswerID: 644288
Follow Up By: qldcamper - Tuesday, Aug 15, 2023 at 15:37
And they continue to get away with it.
FollowupID: 924305
Reply By: RMD - Tuesday, Aug 15, 2023 at 18:20
Axle
You shouldn't advertise that system so others can see it. Chris Bowen will be onto it straight away with 400W on such a small panel. He will have them stuck all over the Tesla we all bought him!
AnswerID: 644289
Reply By: Member - McLaren3030 - Wednesday, Aug 16, 2023 at 06:43
Hi qldcamper,
These sound too good to be true. At 740 gms in weight, they sound like a “flexible” panel. How is the heat that they generate being dissipated? Do they need an air gap under them?
A photo or link to a website would be helpful.
AnswerID: 644291
Follow Up By: qldcamper - Wednesday, Aug 16, 2023 at 07:46
Hi Macca,
It is total crap, there is no way those figures are possible.
Post was to highlight the utterly rediculas claims made in ebay advertising.
People believe this shit.
FollowupID: 924307
Reply By: Andrew L - Friday, Aug 18, 2023 at 14:05
when the suns out, when ts not we will have to revert to cutting trees down
Coal, a trees best friend.
AnswerID: 644299
