Routing on Dirt refuses to work.
Submitted: Wednesday, Sep 06, 2023 at 19:13
TRCB
Im trying to route from Liverpool area to Yerranderie (nsw), the app draws the longest slowest tar route it can via
Oberon or via
Goulburn, completely ignoring the obvious route mittagong/wombeyan/werrong
How can i tell the app it needs to use off road mode and use actual dirt roads?
Reply By: Member - Duncan2H - Thursday, Sep 07, 2023 at 09:01
Just drive it.. no need to route, I never route with ExplorOz personally.. its much more fun and you've got a great situational awareness of where you are, where you're going and the lay of the land...
OK not much help sorry.
644391
Reply By: Briste - Thursday, Sep 07, 2023 at 09:47
Try it again using cycling mode. Works for me. I don't know the road but I assume that's the route you want. You will need to type in a higher average speed when setting the mode.
This is one of those frustrations with EoT, but I can usually get it to choose the route I want my mode selection and adding waypoints.
644392
Follow Up By: IvanTheTerrible - Thursday, Sep 07, 2023 at 19:49
worked on Google maps
924488
Follow Up By: Briste - Thursday, Sep 07, 2023 at 23:42
I stand corrected, the cycling option didn't give you the route you wanted in this particular instance. But Google often doesn't find the route you want either, esp when it comes to dirt roads. Route planning can be an art.
924489
Reply By: Michael ( Moss Vale NSW) - Thursday, Sep 07, 2023 at 22:12
Yes do the Mittagong route, your ordinary GPS will find it once you get to Mittagong. Its a nice drive. Michael
644395
Reply By: ExplorOz - David & Michelle - Friday, Sep 08, 2023 at 00:11
Enter the in between
places you mention to steer it your way and yep try adjusting any segments that don’t go the way you want by inserting more
places and if necessary change mode to cycling which works
well when there’s dirt roads that driving mode doesn’t pick up. Check out the video on this on our YT channel. Auto routing tips and hacks.
644396
