Just when you think you have seen everything
Submitted: Wednesday, Dec 11, 2024 at 15:22
ThreadID: 149282 Views:4037 Replies:11 FollowUps:61
Just seen a post asking where to buy 120mm squared cable for a caravan install. Battery cable doesn't go that big, it's 20% bigger than 0000 B&S.
Maybe just stick some heatshring around some railway track.
Reply By: Member - Racey - Wednesday, Dec 11, 2024 at 16:37
For a large Invertor you need large cables.
AnswerID: 646935
Follow Up By: qldcamper - Wednesday, Dec 11, 2024 at 17:01
Larger than the cables used to start D11 dozers?
Not a very well designed system.
If the inverter is large enough or far away from the batteries to need cable that size then 24 or 48 volts should be considered.
Cost and weight is another issue, decent quality 120mm2 cable is in the vicinity of $85 per metre and comming in at 1.1kg.
FollowupID: 927674
Reply By: Kazza055 - Wednesday, Dec 11, 2024 at 16:51
Maybe use copper busbars .
AnswerID: 646936
Reply By: Member - Bigfish - Wednesday, Dec 11, 2024 at 18:14
This is often used for winch cable in 4wd,s.
AnswerID: 646937
Follow Up By: qldcamper - Wednesday, Dec 11, 2024 at 19:12
120mm squared cable would be way more than a winch would need too.
I'm not even sure what current it would be rated at, the chart I use only goes to 4×0 B&S and that's 399 amps continious, 120 is 20% heavier. If a winch drew anywhere near that for5 minutes it would be toast.
FollowupID: 927678
Follow Up By: Member - Bigfish - Thursday, Dec 12, 2024 at 10:29
Manywinches use 350-400+amps when in use under hard conditions. Using a gauge a lot higher helps illiminate heat and guarantees full amperage is available. Voltage drop is not an issue. Competition winches use higher amps. This cable is a way overkill on a caravan though.
FollowupID: 927681
Follow Up By: qldcamper - Thursday, Dec 12, 2024 at 10:44
How lithium batteries have changed the world. Not that long ago a 350 amp load on a battery for more than a few seconds would have been the end of it.
I'd hate to put my hand on a winch that had been pulling 300 plus amps for 5 minutes.
FollowupID: 927682
Follow Up By: Peter_n_Margaret - Thursday, Dec 12, 2024 at 18:01
What is the CCA of your crank battery? 600A?, 900A?
"CCA measures the number of amps a battery can produce for 30 seconds while maintaining at least 7.2 volts at a temperature of 0°F (-18°C)"
My winch draws 600A at stall.
FollowupID: 927685
Follow Up By: qldcamper - Thursday, Dec 12, 2024 at 18:16
When I was in retail you had to check with the individule battery companies, there was no set parameters for the rating, temperatures and times were often varied and very few brand new batteries held up when we did our own tests just to shut the reps up.
Don't believe everything you read.
FollowupID: 927686
Follow Up By: Peter_n_Margaret - Thursday, Dec 12, 2024 at 18:24
Whatever method they used, it will be a lot more than "a 350 amp load on a battery for more than a few seconds" and it would not be "the end of it".
FollowupID: 927687
Follow Up By: qldcamper - Thursday, Dec 12, 2024 at 18:45
Ahhh yes I forgot, in this forum you can't write anything that may have a slight exaggeration to make a generalisation, I'll have to remember to have a solicitor proofread future posts.
Hope you have a merry and factually perfect christmas.
Oh bugger I didn't use a capital in christmas, so sorry, dam, did it again.
FollowupID: 927688
Follow Up By: Allan B (Sunshine Coast) - Friday, Dec 13, 2024 at 08:07
It is like a sideshow alley QC. The guns are aimed and just waiting for the ducks to appear.
FollowupID: 927689
Follow Up By: qldcamper - Friday, Dec 13, 2024 at 08:35
Too true Allan,the prize should be a box of common sense, but then that would be wasted, better off with a pair of fluffy dice.
FollowupID: 927690
Follow Up By: Member - Ups and Downs - Friday, Dec 13, 2024 at 08:39
Would now be a good time to suggest that the correct spelling is 'damn?'
No, probably not. (Said he having a giggle)
Paul
FollowupID: 927691
Follow Up By: RMD - Friday, Dec 13, 2024 at 16:10
Paul.
Don't start on incorrect SPALLING!
FollowupID: 927695
Reply By: Allan B (Sunshine Coast) - Wednesday, Dec 11, 2024 at 18:37
That,s a hell of a large cable for a caravan application. You would want to be sure that your need was correct.
AnswerID: 646938
Follow Up By: qldcamper - Wednesday, Dec 11, 2024 at 19:05
Maybe if the batteries were on the rear bumper of a 30 foot van and the 8kw inverter was in the drawbar toolbox.
I think it's just he has been listening to to many FB experts.
I can't imagine any practical application it would be needed in a caravan.
FollowupID: 927677
Reply By: Nomadic Navara - Thursday, Dec 12, 2024 at 06:31
"Just seen a post asking where to buy 120mm squared cable for a caravan install."
Where was that posted? Can you please supply a link to it?
AnswerID: 646939
Follow Up By: qldcamper - Thursday, Dec 12, 2024 at 06:40
It was posted in a forum which recieved so much flack the OP deleted the thread.
It was only to run a 3kw inverter.
FollowupID: 927680
Follow Up By: Allan B (Sunshine Coast) - Thursday, Dec 12, 2024 at 13:23
Why “flack”? He probably wants to keep voltdrop under 20mV. lol
FollowupID: 927683
Reply By: tonysmc - Friday, Dec 13, 2024 at 21:52
Well, I’ll be the devils advocate here, but I just had a look at the manual for a Redarc 3000W invertor and it states the recommended cable size is AWG 120 mm squared for cable length 0 - 2m. I can only assume the OP asking the question was just trying to follow the manufactures and suppliers instructions. I would think doing anything less than their recommendation would give an insurance company a great excuse to get out of paying out for a fire? Maybe use 2 smaller cables paired together to the equivalent size?
AnswerID: 646948
Follow Up By: TrevorDavid - Friday, Dec 13, 2024 at 23:03
Probably means something like this
TrevorDavid
dontyajustluvit
FollowupID: 927700
Follow Up By: qldcamper - Saturday, Dec 14, 2024 at 07:59
Both posts very interesting.
Trevor, what brand is that, 4×0 Tycab is just short of 100mm squared.
FollowupID: 927701
Follow Up By: TrevorDavid - Saturday, Dec 14, 2024 at 22:24
QC,
I’m thinking the key word is Nearest.
Elcon Code LHDN120
Nearest AWG 0000 AWG
Strand No. / Size 1653/0.3
Nominal Area (mm²) 120mm
**AMP Rating @ 30°C 487 A
Insulation Thickness V90HT (mm) 1.6mm
Electrical Resistance @ 20°C (ohm/km) 0.2O
Nominal O.D. (mm) 20.0mm
Mass (kg/100m) 124.0kg
Rather large battery cable.
TrevorDavid
dontyajustluvit
FollowupID: 927702
Follow Up By: qldcamper - Sunday, Dec 15, 2024 at 07:37
Yes it seems a bit vague.
I've used tycab cables for many years and CMA before that so have taken their specs as my normal, it is what I am used to.
But looking around a bit different companies seem to call whatever cable whatever they want.
4*0 is ( rounded up or down) 99, 103, 107 and now it seems 120 mm squared, and if I kept looking pretty sure there would be more. There are so many charts on the net it is impossible to find a draught of the original standard, and I doubt it would have even included cable that big. From what I've read it is an algorithm for surface area so all the other specs on the charts should be from the manufacturer depending on what composition of copper its made from, not the people selling it.
I guess when the standard was devised their weren't that many cable manufacturers and in those days the need for battery cable heavier than 4*0 would never be needed especially in 12 volt applications.
Caravan manufacturers will have to go to a 24 volt standard just has every other industry that needs that much energy in single applications.
Even the largest electric drive dump trucks I've seen up close only use 4*0 cables in their propulsion systems, that's all the energy of a 20 cylinder marine diesel engine, but it is done at up to 4kv.
My view is anyone designing a system at 12 volts that needs heavier cable than 100mm squared has been reading too much shit on FB.
FollowupID: 927704
Follow Up By: Nomadic Navara - Sunday, Dec 15, 2024 at 09:17
Quote "There are so many charts on the net it is impossible to find a draught of the original standard, and I doubt it would have even included cable that big."
The original standards are still around. The problem is you have to get into those standards associations, which is a bit like trying to access AS/NZS standards.I think that the people who prepared these Wikipedia pages would have had access to the original information.
IEC 60228 - - https://en.wikipedia.org/wiki/American_wire_gauge - - British Standard Wire Gauge
Use the figures in the tables in those pages to cross check charts from other sources.
FollowupID: 927706
Follow Up By: qldcamper - Sunday, Dec 15, 2024 at 09:56
Thanks for the link Peter,
Is the British Standard BS, the same as the Brown & Sharpe B&S sheet metal gauge that the AWG copies (apparently according to Wikipedia) ?
FollowupID: 927707
Follow Up By: Nomadic Navara - Sunday, Dec 15, 2024 at 10:57
There is also an article on Brown & Sharpe but I did not include it as there was no table within the article. The first paragraph may give you a clue.
I did not have much to do with wire gauges when I was involved with that sort of thing. Our department (DCA) used a sizing that was referred to by the number of strands in a cable times the decimal inch diameter of each strand. The terminology is still used but has been metricated, for example 1.6mm cable would be referred to as 7/0.25 and 3.2mm cable would have been 32/0.2.
FollowupID: 927709
Follow Up By: Nomadic Navara - Sunday, Dec 15, 2024 at 11:13
There is another page to look up Wire gauge. It gives more detail than Allan B offered in the reply following this long one.
The second paragraph under the heading makes mention of Brown & Sharpe. In it, they state "This is now the American wire gauge (AWG), and is prevalent in North America."
FollowupID: 927710
Follow Up By: Allan B (Sunshine Coast) - Sunday, Dec 15, 2024 at 13:08
Yes Peter, the whole thing became a shambles powered by egos and whatever until the ISO standards became norm. The Australian automotive industry still offers cable rated by "Amps" or mm of outside diameter over the plastic!!! Do they have some agenda or are they just stupid?
FollowupID: 927711
Follow Up By: Nomadic Navara - Sunday, Dec 15, 2024 at 15:19
"Do they have some agenda or are they just stupid?"
I think the agenda is to sell something with a large size number with only a small amount of copper in it. The stupid ones are those who purchase it and not looking at the small print to see what they are actually getting.
FollowupID: 927713
Follow Up By: Allan B (Sunshine Coast) - Sunday, Dec 15, 2024 at 16:01
Peter, You may well be right about an "agenda". We are being conned all the time.
FollowupID: 927715
Reply By: Allan B (Sunshine Coast) - Sunday, Dec 15, 2024 at 10:43
Maybe there are some readers who wonder why these early (and current American) wire gauges are expressed in apparently inverse form, i.e. the larger cable = a smaller number.
Wire was made by drawing the material (copper) through a die to extrude into the wire form. And early wires were solid, that is, not stranded.
So the largest wire made was established as being about 1/3 of an inch (8mm) in diameter and termed "0 gauge". Then to produce the next smaller size this initial wire was redrawn through a die to become "1 gauge" (1= first redraw) at about 7mm diameter. This redrawing proceeded with increasing numbers and decreasing diameter.
I can remember in my apprenticeship being presented with the available cable sizes and accepting their size descriptions without giving any consideration that the scale was inverse.
Today, America and maybe some other odd countries cling to the antiquated standard but more progressive countries such as Australia have adopted the metric standard of square millimetres which is infinitely more sensible and easier to work with. Alas, some suppliers in Australia still express in the old "B&S" or "AWG" terms.
AnswerID: 646950
Follow Up By: RMD - Sunday, Dec 15, 2024 at 14:45
Allan.
Although mentioned a while ago, wire is also seen in an INVERSE way for area.
I know the industry and all who work in it, or have to work with it, must accept that the description of area isn't correct. As QLD posted, 120mm squared is 120mm x 120mm conductor size. A real Post indeed. Not true in fact, it isn't a post of solid copper 120mm x 120mm it is 120squared mm, ie, the area of 120 individual square mm. Everytime is see it represented as mm SQ, I have to mentally convert to SQ MM, because that is what they really mean, but it isn't what is stated. it is just as easy to show it as Sqmm. All out of whack to me. The size 120mm sq is 14,400 sqmm. Any surveyor doesn't work the way the electrical industry does with area.
If there is a good reason why it is Frack to Bunt, I would like to know why!
FollowupID: 927712
Follow Up By: Allan B (Sunshine Coast) - Sunday, Dec 15, 2024 at 15:54
Hi R, Permit me to call you by your first name as we appear to be getting along quite well.
I at least, who worked in the electrical industry, do not accept that "the description of area isn't correct" whatever that may be referring to. We certainly use the description correctly, or at least understandably, with convenient shorthand expressions. You will hear electricians saying " Hand me that roll of 6 mil will you?"
He knows, and anyone working with him knows, that he is referring to cable with an area dimension of six square millimetres. If you don't know, then maybe you shouldn't be working with it?
The description of cross sectional area of cable is quite well defined but some difficulty can arise when typing it. My computer keyboard for example does not provide for a superscript 2 which is used to indicate the square function when writing cable area expressions. But understanding that limitation, all but a very few pedantics or plain idiots seem able to accept and understand that when, in context, I write "16 mm2" that I am referring to a cable that has a cross-sectional area of "sixteen squared millimetres" and NOT sixteen millimetres squared. To alternately type it as "16 2mm" could cause perilous confusion in being mistaken for "162" millimetres.
I must say that I have worked with several pedantic fools who never seemed to get the job done with any degree of quality or promptitude, They were a real pain. Don't be one of them by trying to misconstrue the accepted industry shorthands.
FollowupID: 927714
Follow Up By: qldcamper - Sunday, Dec 15, 2024 at 16:36
It works when it's 1mm Allan.
Just keep them on the small jobs.
May I just add,why is wire round when it's measured in square mm?
FollowupID: 927717
Follow Up By: Allan B (Sunshine Coast) - Sunday, Dec 15, 2024 at 16:48
It was once measured in "circular mils" QC. Google it. Just another useless subject that I had to learn…… then never use in practice.
FollowupID: 927718
Follow Up By: qldcamper - Sunday, Dec 15, 2024 at 16:54
That would be fun, how is that one abbriviated in type?
There are a few things they stopped teaching in the last few decades, common sense being the most notable.
FollowupID: 927719
Follow Up By: Allan B (Sunshine Coast) - Sunday, Dec 15, 2024 at 16:57
We didn't have typewriters or word processors when that was in vogue and abbreviation was frowned upon.
FollowupID: 927720
Follow Up By: Member - Happy Explorer - Sunday, Dec 15, 2024 at 17:57
Wow Allan,
How this forum has degenerated in recent times.
Good to know that at least you used the plural so I gain solace in knowing that I am not the only Pedantic Idiot, or was that Plain Idiot, or maybe it was Pedantic Fool. Not sure now but at least I am not the only one.
Thanks for pointing out that it is all quite clear and easy to understand anyway.
So we have:
1. mm squared - which is typed incorrectly but we all should know clearly what that means (tick).
2. B&S - Now was that British Stand or Brown & Sharpe. No real clarity on if they are the same or which one B&S stands for here in Australia (tick)
3. AWG - which I am lead to believe, if it stands for American Wire Gauge will have a larger number for smaller wire and a smaller number for larger wire. That number has no relevance to modern manufacturing processes apparently and would only mean something once one found a chart to ascertain the actual thickness. If you find two charts with conflicting data then you are none the wiser (tick).
If it stands for Australian Wire Gauge then it might represent the outside measurement of the insulation and may or may not have much or any copper in it at all (tick).
4. Something that looks like 7/0.20 or similar. We used that in the security industry back when I was an installer so suspect the industry still does (tick).
I am really pleased that your electrician mate and his TAs know what 6 mil means cause I doubt many outside that tight industry circle would.
At least now, when I next go to buy some cable, I will have a very clear understanding as to what I am looking for. I might even be able to throw off my label (what was it again) as I demonstrate my newly acquired understanding and prowess.
Meanwhile regards
Pedantic Idiot.
FollowupID: 927721
Follow Up By: qldcamper - Sunday, Dec 15, 2024 at 18:14
Glad to see you followed that perfectly.
Australian wire gauge? As far as I knew there is only 3 sizes, thick, or thin fencing wire, and coat-hanger
And next time you go for wire just get 4×0 and call it whatever you want, bet you can't make it smoke.
FollowupID: 927722
Follow Up By: Allan B (Sunshine Coast) - Sunday, Dec 15, 2024 at 18:33
Alright, I'll throw a couple of other favourites into the ring and see if there are any other old sparkies reading.
What was 23/0076 or 40/0076? Most of you would have handled them even though you were unaware.
I have a cigar ready for a correct answer.
It must be a wet day everywhere today. This forum is unusually active.
FollowupID: 927723
Follow Up By: qldcamper - Sunday, Dec 15, 2024 at 18:38
OK I'll have a guess,
I'm not tour kind of sparky,
And I'm not old ( as you anyway lol)
And, I don't like cigars anyway.
My guess, speaker wire?
That was with no google assistance.
FollowupID: 927724
Follow Up By: qldcamper - Sunday, Dec 15, 2024 at 18:42
On a more serious note, I have never used that sizing method as my previous guess might have proved but it has one major advantage I can see.
It would give you an idea as to its flexability which is an important factor.
FollowupID: 927725
Follow Up By: Allan B (Sunshine Coast) - Sunday, Dec 15, 2024 at 18:51
Nup, not speaker wire.
And I didn't think of someone using Google so I'll giver the answer before they do.
They were the two common flexible cable sizes representing 5A and 10A appliance flex.
23 or 40 strands of 0.0076 inch diameter strands.
Represented today by 0.75mmsq and 1.5mmsq approx.
FollowupID: 927726
Follow Up By: qldcamper - Sunday, Dec 15, 2024 at 19:05
Ahhh, that would be the stuff with a slightly raised edge on one side.
FollowupID: 927727
Follow Up By: Allan B (Sunshine Coast) - Sunday, Dec 15, 2024 at 19:06
Ah Happy, I can be pedantic too when I need to, but I try not to do so just to badger someone else.
FollowupID: 927728
Follow Up By: Allan B (Sunshine Coast) - Sunday, Dec 15, 2024 at 19:08
Hi QC, err, no. not the ribbed stuff.
Just common old appliance cords.
FollowupID: 927729
Follow Up By: qldcamper - Sunday, Dec 15, 2024 at 19:17
Bugga, wrong again.
Good thing I don't smoke, never gunna get that cigar.
FollowupID: 927730
Follow Up By: 3ways - Sunday, Dec 15, 2024 at 21:01
Allan 23/0076 was rated at 7.5 amps and 40/0076 rated at 10 amps ref 1969 saa rule book
FollowupID: 927731
Follow Up By: Allan B (Sunshine Coast) - Sunday, Dec 15, 2024 at 22:04
Right.
FollowupID: 927733
Reply By: TrevorDavid - Sunday, Dec 15, 2024 at 21:23
Right T O then.
So old mate that posted the question on the other forum, who then got belted for it, was not asking such a ridiculous question after all.
It was I believe for a 3000w Inverter.
Redarc spec for said Inverter is 120mm² cable.
It is commercially available.
That said, it is a big arse cable for that application, Probably just trying to follow spec.
AND
Are you blokes bored, is it raining or too may cans, Red Wine, Sparkling maybe? Been a good post??
TrevorDavid
dontyajustluvit
AnswerID: 646953
Follow Up By: qldcamper - Monday, Dec 16, 2024 at 08:02
Quite correct but at no stage did he mention that it was recomended by the manufacturer and Redarc is probably the only inverter on the market that you can identify the manufacturer, could be wrong on that, has anyone with a rebranded one able to varify that?
Did the specs you found mention current and minimum voltages required by the unit and maybe the attack time of the over current protection or duration of the surge capacity, with these figures the cable requirements can be calculated.
Then ofcourse you have to trust in the cable manufacturers specs, do you use a generic chart that specifies 0000 as 120mm2 or one by a manufacturer such as Tycab at a bee's dick short of 100mm2.
This also depends on the purity of the copper so the restance/ length also needs to be specified.
With this information Redarcs recomendation can be checked, wouldn't be the first time an error went through un noticed.
Just as a matter of interest, what cable is mentioned by Kings, Hardkorr, itech world or any of the other rebranded inverters specify?
If I was marketing inverters I would not specify cable size, just their requirements and let the installer do the maths based on the products they use.
FollowupID: 927734
Reply By: Member - Ups and Downs - Monday, Dec 16, 2024 at 08:36
Threads on 12v electrics (or is that a nominal 12 volts) have traditionally created arguments.
I think now that I understand why!
Paul
AnswerID: 646955
Follow Up By: qldcamper - Monday, Dec 16, 2024 at 08:53
Wasn't aware anyone was arguing, just putting forward varying "facts" found on the Web that are in conflict and confirming the fact that the inexperienced must be very careful on what information gathered in this medium they concieve as true.
It's human nature to believe what you read, it is how we were taught to educate ourselves, so someone that has no personal experience is more likley to believe what has been written by someone with little or no more experience than they have and ignore advice from people that have trained under experience tradesmen and had technical training and in many cases decades of personal experience.
Not arguing, discussing.
FollowupID: 927735
Follow Up By: Member - Ups and Downs - Monday, Dec 16, 2024 at 09:06
Argument:
'a reason or set of reasons given in support of an idea, action or theory.'
I was using the word argument in the above context.
Paul
FollowupID: 927736
Follow Up By: qldcamper - Monday, Dec 16, 2024 at 09:11
Now your arguing about my response to your post.
I'm quite happy to call it a discussion, you can call it whatever you like.
If you want to argue I would recomend you start your own thread and argue about what what defines an arguement with whoever actually cares.
FollowupID: 927737
Follow Up By: Allan B (Sunshine Coast) - Monday, Dec 16, 2024 at 10:30
The word "argument" is well defined in any good dictionary. It is essentially a word to define the putting forward a reason(s) to support a conclusion and is not necessarily antagonistic. It can be qualified by such as 'reasoned argument' 'heated argument' 'futile argument' etc..
It is often used incorrectly where the proper word would be "quarrel".
There is no doubt that this thread is enacting an argument. Hopefully it will not become a quarrel.
FollowupID: 927738
Follow Up By: qldcamper - Monday, Dec 16, 2024 at 10:39
Feel free to discuss it with ups and downs in a thread he/she is about to start.
FollowupID: 927739
Reply By: Allan B (Sunshine Coast) - Monday, Dec 16, 2024 at 11:02
As a matter of interest and perhaps in support of the Redarc recommendations, the Enerdrive instruction for their 2600W inverter (their largest) indicate a "Minimum size input cable" as being 120mm2 with a maximum length of 1.5m. I could see no expression of their full-load 12vdc current.
Like Redarc, Enerdrive are noted for their reliability and quality of technical specifications.
Of course, you could calculate the required cable requirement if you so wished and were confident in your ability to do so, but is there any reason to question two (or more) reliable manufacturers who will not gain benefit from the purchase of such cable?
I must confess that I was initially surprised at the 120mm2 proposal but I had never needed to consider it before and I jumped to a conclusion. I should have known better having followed the writings on the American MB Sprinter motorhome forum site. Boy, do those guys know how to specify and install mega power systems!!! 4x0000 cabling is not just usual, it is de rigueur and often just a starting point.
AnswerID: 646956
Reply By: qldcamper - Monday, Dec 16, 2024 at 11:59
Maybe I should revise my thoughts of a 3kw inverter being the max on a 12 volt system to not practical at 12 volts.
1.5 metres is a bit restricting seeing lithium batteries are required to be in their own enclosure. Also terminal bolt diameter becomes an issue.
Was at BCF recently and their 3kw inverter wiring kit was 000, not sure of the brand.
Obviously there a lot of varying opinions between engineers out there.
If cable 20% bigger than 0000 is recomended then what size battery will be needed to deliver such large amounts of current?
Starting to become incredibly expensive.
Think I will stick to working out my own cable sizes with a brand I know and trust.
Won't be long till someone wants to run
an electric instantaneous hot water system in their camper van.
And what about warranties and insurance.
It's all well and good that the manufacturer states minimum requirements, that covers them. The installer purchases cable marketed as 120mm2 but it is really 102mm2 and something goes wrong,the installers insurance company(prey he has one) will need to claim against the cable supplier who will blame the importer and so on, who is really at fault, God knows but the inverter manufacturer is covered by a figure they come up with.
Allan, just out of curiosity, what size fuse do they recomend?
Can you tell it's raining here again?
AnswerID: 646957
Follow Up By: Allan B (Sunshine Coast) - Monday, Dec 16, 2024 at 12:22
Enerdrive nominate a 350A fuse QC.
Isn't it raining everywhere?
FollowupID: 927741
Follow Up By: qldcamper - Monday, Dec 16, 2024 at 12:43
Strange.
They must have a very low tolerance to voltage drop.
Tycabs 0000 is close to 100mm2 and rated to carry almost 400 amps.
Yet 120mm2 cable fused at 350 amps.
Still don't know what 120mm2 cable would be rated to carry but one could assume 20% more than 100mm2.
120 seems very over rated for a 1.5 metre run.
I guess it's allowing for the low quality and or incorrectly sized cable out there.
FollowupID: 927742
Follow Up By: tonysmc - Monday, Dec 16, 2024 at 12:52
Qldcamper, the size fuse Redarc recommends is a Mega 450 amp.
FollowupID: 927743
Follow Up By: qldcamper - Monday, Dec 16, 2024 at 12:57
Do they specify a cable length Tony?
FollowupID: 927744
Follow Up By: Allan B (Sunshine Coast) - Monday, Dec 16, 2024 at 13:00
No, their specs are reasonable generous as follows……..
Operating range: 10.5v to 15.5v
Under voltage alarm: Adjustable 11.0v to 12.1v
Under voltage shutdown: Adjustable 10.5v to 11.8v
Make what you will of it.
Perhaps the 120mm2 cable recommendation is just to obtain a minimal volt drop and ensure best possible performance. I don't care to ask them.
FollowupID: 927745
Follow Up By: qldcamper - Monday, Dec 16, 2024 at 13:12
What is known in the mining industry as ACE.
FollowupID: 927746
Follow Up By: Allan B (Sunshine Coast) - Monday, Dec 16, 2024 at 13:20
Some sort of … Covering Exercise?
FollowupID: 927747
Follow Up By: tonysmc - Monday, Dec 16, 2024 at 13:24
Yes, cable length of 0 - 2m
FollowupID: 927748
Follow Up By: qldcamper - Monday, Dec 16, 2024 at 13:32
You got that right Allan.
Tony, least their fuse size is close to the cable capacity assuming true 120mm2 is rated at close to 500 amps.
FollowupID: 927749
Follow Up By: qldcamper - Monday, Dec 16, 2024 at 19:00
Now it's getting confusing.
FollowupID: 927756
Follow Up By: qldcamper - Monday, Dec 16, 2024 at 19:20
OK found it on the Tycab site, it is weldflex and on the chart I found it on it has no reference to a B&S size or rated current capacity.
It may fit the same terminals as 0000 as weldflex has more strands of a smaller diameter than battery cable so less air space between strands so smaller overall diameter of a battery cable with the same surface area. Weldflex has always had a higher throughput than a similar thickness battery cable and is much easier to work with but its insulation is nowhere near as tough as battery cable.
There is however a ebay seller calling it 0000 but so far have not seen it on the Tycab site.
FollowupID: 927757
