Saving memory
Submitted: Thursday, Feb 13, 2025 at 13:01
ThreadID: 149641 Views:2332 Replies:3 FollowUps:9
How can I reduce memory ExploreOz is taking up on my iPad as I am running out of space?
Reply By: Member - A_P - Thursday, Feb 13, 2025 at 16:32
The maps make up the bulk of the space . Are you using the current version and new maps? The previous version maps might still be there taking up space. Try deleting app and reinstalling
AnswerID: 647373
Follow Up By: Nomadic Navara - Thursday, Feb 13, 2025 at 17:19
Maybe dump some other stuff you don't use much. Photos and the like can be put on a USB stick.
FollowupID: 928365
Follow Up By: Member - Andrew W14 - Monday, Feb 17, 2025 at 15:01
Thanks mate, tried that exercise already ,but still short of memory to update. iPad does not havev USB ports. Also it’s non cellular so SIM idea won’t work. Guess it’s time to buy another or forget updating.
FollowupID: 928432
Follow Up By: Member - Jim S1 - Monday, Feb 17, 2025 at 17:55
Yep , a new iPad with (more than) sufficient memory . Has never failed me.
Jim
FollowupID: 928437
Follow Up By: Member - Warren H - Tuesday, Feb 18, 2025 at 16:20
You just need an adaptor to go from the Apple port to a regular usb or a cable with the Apple plug that goes to the external device.
NT Pajero
2007 Goldstream Crown
FollowupID: 928450
Follow Up By: Bob Y. - Qld - Wednesday, Feb 19, 2025 at 09:08
Most of latest IPads are fitted with a USB “C” port, so transferring data is much easier.
FollowupID: 928458
Follow Up By: Nomadic Navara - Wednesday, Feb 19, 2025 at 11:09
Quote "iPad does not havev USB ports."
But does its Lightning connector connect to peripheral memory? Have a look at this one - SanDisk iXpand Lightning and USB Type-C Flash Drive (128GB) - There are many other USB drives with Lightning connectors, but I selected that one as it will also allow you to connect it with future new generation equipment that you may purchase.
More of the same thing - you should already have something like this to backup your iPad.
FollowupID: 928460
Reply By: Member - Bigfish - Sunday, Feb 16, 2025 at 16:27
Load the maps onto a SIM card...assumming you can put a sim into an ipad. Store on there instead of the pads internal memory.
AnswerID: 647412
Follow Up By: Member - Warren H - Monday, Feb 17, 2025 at 14:08
Bigfish, I presume you mean a microsd card? I believe that with an iPad you're stuck with internal memory as purchased. You can add an external drive but I don't know if it's storage only or you can configure apps to use the drive, as opposed to say storing photos say that you can then load into an app for processing.
NT Pajero
FollowupID: 928429
Reply By: Allan B (Sunshine Coast) - Wednesday, Feb 19, 2025 at 11:20
There is a lot of expressions of "memory" here when I think "storage" is meant. There is a difference and the distinction is important.
I think Andrew is really concerned with storage rather than memory (RAM) and the distinction is vital when looking at device specifications, especially when assessing a product for purchase.
AnswerID: 647432
Follow Up By: Member - Andrew W14 - Wednesday, Feb 19, 2025 at 12:20
Correct Allan. Thanks for clarifying. Storage is my real issue as whilst the iPad still functions well enough to run ExploreOz, there is not enough storage left to do an update. It’s only a 64 gig version so not unexpected. However, whilst fully aware a new model would solve this issue, it seems a waste to spend $1200 or so on a new one without investigating if anything can be done ( besides photos, apps etc) to release more storage.
FollowupID: 928461
Follow Up By: Allan B (Sunshine Coast) - Wednesday, Feb 19, 2025 at 12:59
Hi Andrew,
Peter's (Nomadic Navara) proposal above for a Flash Drive with Apple Lighting connection may solve the problem economically.
Although bear in mind that if your current iPad does not have SIM & internal GPS receiver you will not be able to utilise some of Traveller's features.
If you do upgrade your tablet it may be sufficient for you to choose other than iPad. Samsung (my choice) make excellent tablets with internal GPS and plenty of storage at much cheaper than iPad. Add a SIM card and a data plan and you will have the benefit of internet access and email etc.
FollowupID: 928462
