Red-arc boost/EGT gauge issue
Submitted: Friday, Feb 21, 2025 at 23:30
ThreadID: 149707 Views:2853 Replies:1 FollowUps:0
Hey all, new to the forum, apologies if it's in incorrect section or whatever hah!
I've just installed a G52-BET Red-arc boost/EGT with optional temp sensor gauge in my hj75 that was originally in my hj60 a couple years ago.
My issue is, the EGT warning goes off and sits above 700 deg without even plugging the egt connector in or even starting the engine?
As soon as i turn on the ign it goes off! If i remove the module harness it settles down, so ive replaced the harness as i thought it might the problem, only thing left is the module, which would be a new gauge purchase as you cannot buy them separately.
I don't remember this happening when I previously installed it in my 60, has any one had this or any tips
P.s my wiring and install is spot on as I hate shitty wiring work later on haha!
Sorry for the long winded post
Cheers ??
Reply By: J0hno - Saturday, Feb 22, 2025 at 01:46
Update! The pos wire inside the green plug had come out of its post, but still tight in the plug until I done old 10lbs pull test! Phew
AnswerID: 647445
