300 watt solar panel
Submitted: Friday, Feb 28, 2025 at 21:45
ThreadID: 149786 Views:3801 Replies:4 FollowUps:12
Hello folks
I’m on the lookout for a a solar panel which is unregulated with a blue plug on the cable so it plugs directly into my Van so it will not be fixed to my van that’s one option but I would prefer to upgrade my solar panels to a greater power source and have them fixed to the van so currently I’m in Victoria looking for any recommendations before I head off to Darwin thanks Craig
Reply By: Member - Happy Explorer - Saturday, Mar 01, 2025 at 07:32
Hi Craig
The no regulator idea is fine, just remove it and discard provided the panel output is within the limits acceptable to your charger.
What are you plugging it into on your van?
You will need to offer more information.
Roy
AnswerID: 647491
Follow Up By: Craig S20 - Saturday, Mar 01, 2025 at 11:00
Yes Roy the blue plug is on the chassis beside the battery box I’ve got a BM Pro battery management system installed
FollowupID: 928545
Reply By: Nomadic Navara - Saturday, Mar 01, 2025 at 08:08
"with a blue plug on the cable so it plugs directly into my Van"
What is this "blue pug?" You don't need to purchase a panel with any particular plug on it. Get a panel without any plugs and get someone to put the required connector on it. If your best value panel has the wrong connector on it, just get it changed. There is no sense in attempting to get the required item when you can get a better value deal and change the connector.
AnswerID: 647492
Follow Up By: Michael ( Moss Vale NSW) - Saturday, Mar 01, 2025 at 08:18
The Blue plug is possibly a 50 amp Anderson, not a lot of information supplied. Michael
FollowupID: 928539
Follow Up By: Craig S20 - Saturday, Mar 01, 2025 at 11:02
Thanks Peter I’ll take that onboard and shop around
FollowupID: 928546
Follow Up By: Member - David M (SA) - Sunday, Mar 02, 2025 at 08:46
The "blue pug?" is a small Norwegian dog.
Dave.
FollowupID: 928556
Reply By: RMD - Saturday, Mar 01, 2025 at 09:11
Craig S20
That is a big long sentence without much information. A 300 watt panel will be HEAVY and impractical. You need to make sure the charger, ie, like in a JAYCO, can accept the Open circuit voltage of the panel. MAKE sure so you don't fry the charger.
A blue plug is not needed but if you want it to be BLUE, simply write "BLUE" on the GREY PLUG fitted to the leads.
You also hinted in that sentence about increasing wattage of current van panels. But again that can be done, but TOTAL wattage and associated VOLTAGE produced must be below the charger input threshold, ie. total ability, or the charger will be damaged.
Maybe try explaining each objective in it's own sentence so people here can address it for you.
AnswerID: 647494
Follow Up By: Nomadic Navara - Saturday, Mar 01, 2025 at 10:38
Yes, start a new sentence for every thought or topic, then we will know your intentions or questions.
FollowupID: 928544
Follow Up By: Craig S20 - Saturday, Mar 01, 2025 at 15:17
Gday RMD
I have a blue plug on the chassis next to the battery box the grey plug is not compatible with the blue hence the need for a blue plug on the lead from the solar panel I have a battery management system installed and it’s my understanding that this will monitor all the power inputs Granted you could be right with a 300 watt panel being to big so I’ll consider that in my thinking cheers
FollowupID: 928547
Follow Up By: RMD - Saturday, Mar 01, 2025 at 15:43
Craig S20
Ok, if Blue isn't compatible with a Grey, then I would change the Blue one, Mark it SOLAR INPUT, but having a normal Grey plug will enable any solar panel of "suitable specs" to be connected to your system as an AUX power source. OR buy a Blue and a GREY plug and have them connected to a short thick cable. that way it allows either a Blue source or a Grey source vie the two PLUG LEAD. My Jayco has what you describe but it is GREY in a BLACK enclosure and runs directly to the SOLAR input of the charger in van.
It is VERY important to know the AUX SOLAR INPUT VALUE of OPEN CIRCUIT VOLTS and MAX AMPS/ Generated so charger is not fried. It is best if you, or someone with a Multimeter can measure the PANEL Open Circuit VOLTS, IN FULL GOOD SUN and also the DIRECT SHORT CIRCUIT CURRENT it produces. Volts X amps = WATTS and that should be not more than the CHARGERS ability.
Does the Blue plug wiring go to the charger?
You need to know exactly what you have, and if possible, it's connections to CHARGERS and BATTERIES so problems are not created.
FollowupID: 928548
Follow Up By: Craig S20 - Saturday, Mar 01, 2025 at 16:46
Thanks RMD yes the blue plug goes to the charger not sure of volts at this stage overcast day today so I’ll have a look at that later thanks
FollowupID: 928549
Follow Up By: Member - silkwood - Tuesday, Mar 04, 2025 at 09:29
He has a blue Anderson plug, which is designed to go only with another blue Anderson plug, so it can be used only for the intended use (in this case, solar) and not be accidentally used for any other purpose. You are recommending he change the existing blue plug (on the vehicle) for a grey plug so it suits a panel he purchases. If he has to change a plug, why not simply change the panel plug nd retain the safety factor (apart from the fact it would be easier)?
Note: not addressing the voltage/amperage requirements here...
FollowupID: 928578
Follow Up By: Member - Ups and Downs - Wednesday, Mar 05, 2025 at 07:43
I originally had all Grey Anderson plugs.
Then had the bright idea to change to a Red connector on the cables from the solar panels to the regulators.
Damn nuisance as the different leads I had to connect other bits and pieces to power then required an adaptor.
So changed all back to grey and it is much simpler to hook up whatever to whatever.
Works for me.
FollowupID: 928597
Reply By: Craig S20 - Wednesday, Mar 05, 2025 at 09:52
Can anyone steer me in the right direction to get a portable solar panel in and around Melbourne please
AnswerID: 647528
Follow Up By: Member - McLaren3030 - Thursday, Mar 06, 2025 at 07:38
Hi Craig S20,
Jaycar sell a few different types of Solar Panels, some Auto. Elec. also sell Panels, and ARB stores sell them.
FollowupID: 928607
Follow Up By: Peter_n_Margaret - Thursday, Mar 06, 2025 at 17:38
Solar4RVs in Melbourne have a reputation for quality products.
Contact and address.
Portable panels
Recent customer, no affiliation.
FollowupID: 928610
