Comparison of Best Portable 4x4 Fridges (Feedback Request)
Hi all, hope this is ok to share here.
What started as a personal spreadsheet for my 4x4 fridge research has evolved into this comparison tool: 4x4compare.com.au/portable-fridges/
I wanted to share it in case others find it helpful and also get some feedback or suggestions for improvement.
It lets you:
- Filter by brand and/or configuration
- Compare key specs side-by-side (capacity, dimensions, weight, power consumption, etc.)
- View important details like compressor type, insulation, and warranty information
It's not perfect and works best on desktop, but wanted to share it and hopefully get some feedback or suggestions for improvement:
- Any brands or models I should add?
- Features that would make this more useful?
It's been a fun little project so keen to continue with it! Thanks for checking it out.
Reply By: axle - Monday, Mar 03, 2025 at 13:39
Good luck, mate!
Your not trying to start a war by any chance are you?
Cheers Axle.
AnswerID: 647508
Reply By: Peter_n_Margaret - Monday, Mar 03, 2025 at 13:57
"Power consumption Ah" makes no sense.
Do you mean A? If so you also need to quote at what voltage (I note you have).
Even then it is of little value if there is no duty cycle indicated.
If you do mean Ah, then again it needs to indicate at what voltage (again, you have) and over what period.
Getting this information from a reliable source may well be problematic.
A better description would be "Watts" (for power) and "Watt Hours- per day" (for energy).
AnswerID: 647509
Follow Up By: Member - McLaren3030 - Tuesday, Mar 04, 2025 at 07:15
Hi Pete,
I would have thought that AmpHrs would be the most appropriate number as most people would be using this number to determine the capacity of the battery they will need. As you know capacity is measured in AmpHrs, not Watt Hours. Just my thoughts.
FollowupID: 928576
Follow Up By: Peter_n_Margaret - Tuesday, Mar 04, 2025 at 09:34
"AmpHrs" is certainly in common usage in the RV industry Macca, but no where else, and it is generally assumed to be at 12V. Problem is, things are changing like never before.
If you buy a battery for your house solar system, it is rated at kWh (along with the solar) and many of us are going Lithium in our RVs with a nominal 12.8V (or maybe higher) instead of 12V.
So the value of an "Ahr" can not be safely assumed any more.
What prompted my post however was that some of the values looked like they might have been Amps draw rather than Ahrs consumption. For similar reasons to above, Watts takes away any possible confusion and equally applies to the 240V fridges (and other appliances) that many are running via inverters in their RVs. Those inverters quote power capability in Watts, not Amps.
The OP has produced a great body of work (and he did ask for feedback). My post was intended to be constructive. :)
ps... as I said in my post, getting reliable energy consumption information will be problematic. The power (Amps - watts) number is likely to be more accurate, but it is the energy (Ahrs - Watt hours) number that is harder to establish because it can be so variable. It is also the only number that is really important which makes it quite a challenge.
FollowupID: 928579
Follow Up By: Allan B (Sunshine Coast) - Tuesday, Mar 04, 2025 at 11:29
Peter is quite right in all he has said above. The correct way to define the instantaneous power is in Watts which takes care of voltage variation.
Even then, when describing the usage of an appliance such as a fridge it only has information value if the usage (Watts) is incorporated with a definition of the period that this consumption took place, say "per hour" or "per day". A better expression is to define the consumption in 'Watt hours' (Wh) which then clearly defines just how much energy the appliance consumes in use.
There is no reason for us to not use the correct terms of "Watts" and "Watt hours" . But good luck in getting that accepted in common usage. The auto industry abounds with imprecise definitions.
FollowupID: 928580
Follow Up By: Peter_n_Margaret - Tuesday, Mar 04, 2025 at 13:26
We also see confusion between the terms "power" (watts or 'Amps @ 12V') and "energy" (Watt hours or Amp hours @ 12V). I have to think twice each time I use the terms and I often mix up power and energy.
I think it is a legal requirement for AC appliances to state the input power requirement on their compliance plate. I have looked at a few of the fridge specs and it is often just missing.
And "Amps" is neither power nor energy, notwithstanding batteries being commonly described as "100 Amps".
As an extra complication, the Secop/Danfoss compressors are variable speed (others may be too), so the input watts can vary depending on the speed that it is set to run at. That variation in speed also effects the efficiency of the compressor. Provided it is producing sufficient cooling, the slower the compressor is set to run at (and the longer the duty cycle), the less total energy it will use.
There is an expensive accessory that automatically adjusts the compressor speed to maximise the duty cycle, while maintaining sufficient cooling for the use and temperatures, that minimises the total energy consumed. Very clever, but excy.
It is a complicated subject and full of compromises. The OP's chart is a very valuable tool, especially so if the electrical comparison is legit.
FollowupID: 928582
Follow Up By: Allan B (Sunshine Coast) - Tuesday, Mar 04, 2025 at 18:16
Don't worry Peter, although I have been doing it for a lot of years, I also hesitate when assigning "power" or "energy" to consider that I have chosen the correct one…… and still may occasionally get it wrong if I am being inattentive.
When an appliance is constructed to run at variable power levels it is usual (and reasonable) to rate it at only the highest level.
Yes, it is a "complicated subject" but I don't know that I would use the term "compromises". Omissions or inexactitudes perhaps?
FollowupID: 928589
Follow Up By: Peter_n_Margaret - Tuesday, Mar 04, 2025 at 18:40
There are compromises when choosing one product Vs another Allan and what is important to each application determines the choice.
Your "best" fridge might be well down the list for me.
When I built our OKA 20 years ago, minimising energy consumption was important. Solar panels cost $9/watt. I did a DIY freezer because nothing on offer suited my perceived needs at that time. It was small (25L) and had 150mm of quality polyurethane insulation all around and a remote compressor. I also added extra insulation around the fridge which also had a remote compressor that made that easy.
The result was high performance with minimal power.
I am now building a new OKA. Solar is cheap. I will use a 200L+ commercially made fridge/freezer, an inverter and lots of solar.
FollowupID: 928591
Follow Up By: Allan B (Sunshine Coast) - Tuesday, Mar 04, 2025 at 19:07
Ah, I see what you mean Peter. "compromises" in product choice. Yes, there always is.
I was trying to fit "compromises" into the subject of Watts, Ah, and energy etc.
FollowupID: 928592
Follow Up By: Tony W - Wednesday, Mar 19, 2025 at 06:38
"We also see confusion between the terms "power" (watts or 'Amps @ 12V') and "energy" (Watt hours or Amp hours @ 12V). I have to think twice each time I use the terms and I often mix up power and energy."
Since we are being pedantic, Amp hours isn't a unit of energy. It's a unit of charge.
FollowupID: 928680
Reply By: RMD - Monday, Mar 03, 2025 at 16:55
G'day Randall.
A good exercise, but the Kings fridge mentioned, (they have MANY), uses only 1.8AH for a 90 Litre unit?? REALLY! I regard most of those figures as being pretty useless, because it is the ACTUAL current draw and the run time for whatever you use it for which counts. If your use doesn't coincide with the specs test, then HMMM. Recently for $188 I purchased a Kings 30 Litre fridge/freezer which draws 3.6 amps while running, It is by far the quietest fridge I own, Engel 39Lbeing the noisiest by far. I CANNOT ever see my 30 Litre Kings EVER getting down to 1.8 ah usage under any conditions or any of the others either. The Kings 90L must be best ever on the market at 1.8AH!
AnswerID: 647511
Follow Up By: Kazza055 - Monday, Mar 03, 2025 at 18:25
Same with the Brass Monkeys, my 50 & 60L are not listed but then there is about 10-12 different sizes.
FollowupID: 928571
Follow Up By: Gronk - Monday, Mar 03, 2025 at 22:11
For a 3.6 amps while running fridge to get to 1.8AH, all it has to do is run for only 1/2 the time in one hour !
Quite feasible to have a fridge run for 10 mins and rest for 10 mins !
FollowupID: 928574
Follow Up By: RMD - Tuesday, Mar 04, 2025 at 08:55
Gronk
I agree, but the test conditions the fridges are operated in are not the same conditions the fridges are USED in. In the rear of a wagon or under a metal canopy the ambient will be higher and the run times simply go out the window. Just expect more battery needed.
FollowupID: 928577
Follow Up By: Member - nick boab - Tuesday, Mar 04, 2025 at 14:07
I would presume the figures in the comparison are from the manifactors and not the opps own test ?
FollowupID: 928583
Follow Up By: RMD - Tuesday, Mar 04, 2025 at 14:18
Power consumption seems to have disappeared.
FollowupID: 928584
Follow Up By: 2517. - Tuesday, Mar 04, 2025 at 14:21
Hi I was surprised when a King saleman told me there frigs have a 5 year replacement warranty if it fails bring it back and we will exchange .
FollowupID: 928585
Follow Up By: Kazza055 - Tuesday, Mar 04, 2025 at 17:17
Jaycar & RTM have 3 years on the Brass Monkey, just swap them out for a new one.
FollowupID: 928587
Reply By: Member - Jim S1 - Monday, Mar 03, 2025 at 17:20
Thanks for sharing all your hard work. Sure it will be useful for more than a few.
Jim
AnswerID: 647512
Reply By: troopy 47 - Monday, Mar 03, 2025 at 21:12
I think what used to be a great forum has gone to shit with all the people that think they no everything and reply with some smart arse comment. The guy thought it might have been some help. I will be quite happy to be no part of this forum any longer.
AnswerID: 647513
Follow Up By: IvanTheTerrible - Monday, Mar 03, 2025 at 21:30
It is what it is and your leaving wont change a thing but if you stay you can set a example even if nobody follows it.
FollowupID: 928573
Follow Up By: qldcamper - Tuesday, Mar 04, 2025 at 06:55
It isn't just this forum Troopy, it's the whole country, a couple of generations of people that think they know everything because they can google till they find other pretenders that preach the same misconceptions they do.
For some unknown reason it's human nature to believe what we read, it is how the schools taught us to learn, but now most of the literature is written by retards with more lithium in their system than the electrical systems they are pretending to be experts on.
FollowupID: 928575
Follow Up By: Batt's - Wednesday, Mar 05, 2025 at 17:49
Bye Troopy
FollowupID: 928602
Reply By: troopy 47 - Tuesday, Mar 04, 2025 at 07:02
Well said.
AnswerID: 647515
Follow Up By: Batt's - Wednesday, Mar 05, 2025 at 17:51
Couldn't stay away hey you only lasted 10 hours it's just an observation after the previous statement.
FollowupID: 928603
Reply By: Member - Duncan2H - Tuesday, Mar 04, 2025 at 07:09
Useful, thanks!
AnswerID: 647516
Reply By: Member - nick boab - Tuesday, Mar 04, 2025 at 08:33
Thanks Randall: Your fridge comparison would be a handy thing for people researching fridges in this website..
If this was to come up in the articles section keeping it handy when searching fridges
And the article could be edited and updated As Time Goes By with more fridges etc.
I'm not sure how you create and article though .
Cheers . Great work.
AnswerID: 647517
Reply By: Member - LeighW - Wednesday, Mar 05, 2025 at 12:00
Thanks Randall,
The spread sheet would be very helpful for those in need of a new fridge saving a lot of research time. I think the negative feedback about how important specifying volts or wattage above is just rediculous.
The fridge manufactures themselves as far as I have seen specify consumption at 12V/24V and anyone looking at Ah with regards to purchasing a 12V fridge for example would expect the Ah stated in the specs are at 12V. We are talking units designed to be plugged into a vechiles 12V electrical system and how often is it operating at exactly 12V so manufacturers use the standard 12V/24V and I would be very surprised to see different. Your spread sheet allowed for a quick comparison of Ah consumption of different brands and models.
AnswerID: 647529
Follow Up By: Tony W - Saturday, Mar 08, 2025 at 07:17
Well said Leigh. And agreed the table is a great start to help looking for a fridge.
The self appointed experts advocating Wh apparently have little real world experience.
Battery capacity is stated in Ah, and the useful time a fridge can be used is simply the available battery capacity ( Ah) divided by the Ah per day or per hour. Simple. Thats why fridge manufacturers use that unit of measurement.
Using watts or watt-hours complicates the calculation for no benefit since the ( near) constant 12V - close enough for the calsc( given other variables like temp, current draw, battery age, use profile, etc)
That's basic year 8 maths.
FollowupID: 928623
Follow Up By: Allan B (Sunshine Coast) - Saturday, Mar 08, 2025 at 10:39
"That's basic year 8 maths."
Yes, of course it is Tony.
FollowupID: 928630
Reply By: Macquarie - Friday, Mar 07, 2025 at 11:35
Thanks HR- a lot of good work on your part.
One popular brand worth having a look at is WACO. Perhaps not as prominent now with flood of other brands, but a good product.
AnswerID: 647545
Follow Up By: Nomadic Navara - Friday, Mar 07, 2025 at 14:08
" Perhaps not as prominent now"
Maybe that's because:
1. They were spelt Waeco
2. Dometic have taken them over and rebranded them.
FollowupID: 928621
Reply By: Member - Cuppa - Tuesday, Mar 11, 2025 at 19:45
Oh how I wish there had been such a comprehensive comparison when I was looking for a 35 litre unit to use as a freezer only 6 months ago.
I would have happily purchased another ARB 'Classic' unit, but it was too tall for my space. I tried 2 x Bushmans but neither could sustain minus 18 degrees in between 4 & 10 degrees ambient (ie did not cycle). 2 x Dometic CFX 35's were worse. (ok as a fridge, but as a freezer were complete rubbish) In the end I tried an Engel MT-V35F & was happy with it. In recent days of up to 44 degrees ambient for 3 days in a row I've had it full of meat & set on minus 16 & it has done the job. Better as a freezer too than some as the compressor unit is at the end of the box, rather than set in it with a 'butter shelf' above. So the whole freezer is a single 'cube'. So a suggestion would be to perhaps include the 'shape' of the interior. Comments on suitability as a freezer only would also be useful, but of course that would require testing rather than relying on info from the manufacturer.
I should state that both Bushman & BCF (Dometic) were very good about the returned units.
AnswerID: 647573
