Android tablet gps
Submitted: Monday, Apr 28, 2025 at 21:10
Cruznoz
I've been given a Teclast T60Ai_ROW tablet to try, which is supposed to have a GPS going by what I've read online. But the Oziexplorer app that I installed on the tablet (Trail version) is telling me there is no gps (gnss) hardware on the device. Am I missing something and haven't turned something on? Any advice would be appreciated.
Reply By: Peter_n_Margaret - Monday, Apr 28, 2025 at 23:53
No idea about the tablet, but a plug-in GPS is just a few bucks if it needs one.
647850
Follow Up By: Cruznoz - Tuesday, Apr 29, 2025 at 07:38
Thanks Peter
928951
Follow Up By: Member - nick boab - Wednesday, Apr 30, 2025 at 07:16
Also to that Peter in a ExplorOz tutorial David said an external GPS was a good option
928955
Follow Up By: Member - McLaren3030 - Wednesday, Apr 30, 2025 at 08:24
Hi Guys,
An external GPS is a great option, I use a “Bad Elf” external GPS myself. The only drawback is that you cannot keep your tablet charged at the same time that the external GPS is being used, as it uses the same port on the tablet to plug into as the charging cable.
928956
Follow Up By: Member - nick boab - Wednesday, Apr 30, 2025 at 08:43
Macca : I think you can use a piggyback charger connection to run both ??
928957
Follow Up By: Member - McLaren3030 - Thursday, May 01, 2025 at 07:26
Hi Nick,
Thanks for the info, I will check it out.
928959
Reply By: Member - Duncan2H - Tuesday, Apr 29, 2025 at 07:09
Specs are here:
https://en.teclast.com/products/t60ai-tablet
No mention of GNSS receiver. And given it doesn't have any cellular hardware the chances are low that it has GNSS hardware.
Install a simple speedometer app as a second test..
647851
Follow Up By: Cruznoz - Tuesday, Apr 29, 2025 at 07:51
Thanks. I'll try that
928952
