Advice: Renovating 1978 Franklin Snipe Caravan
Submitted: Friday, Jul 11, 2025 at 23:02
StephJane
Hi everyone!
First time caravan owner here, and I've just bought a 1978
Franklin Snipe to fix up.
I was wondering if anyone has reno'd one before?
Looking for first timer advice, tips and tricks.
Finding it quite difficult to find any of the Snipe's with the hard side pop top like
mine has.
Thanks!
Reply By: Member - Bigfish - Saturday, Jul 12, 2025 at 06:05
Have never reno'd a van before but I would reckon that the first thing to ensure is that there is no
water damage anywhere. If there is then I,d say this is vital to have fixed before contemplating anything else. I think that you-tube would have numerous videos on renovating a van. The decor is that of an older van but if it is clean and functional why try and make it something it is not? Maybe new style covers for the setee, lick of paint on the ceiling and some more modern looking lino on the floor. Maybe some new kick boards around the setee base to match the lino. The van looks in good condition and as it is an older model I wouldn't go overboard in a reno project. LED lights, maybe a portable convection stove top, good
water pump and fit Lithium batteries to lower weight and extra power
reserves. Solar on the roof. Renew bearings and brakes.Good luck..shouldn,t be a big project but a satisfying one.
648250
Reply By: Member - Ups and Downs - Saturday, Jul 12, 2025 at 08:13
Not a
Franklin, but I renovated an old Supreme Getaway.
Stripped off the cladding, fixed some damaged frame timber, rewired all 12 volt gear, added a lithium battery, deleted 240v except for 2 power points internally and one outside, installed new electric
water pump and plumbing, new LED lighting along with phone/tablet charging points. New hubs with electric braking, new tyres, new poptop skirt.
Fitted new cladding.
End result is a fully functional off road van that cost just over $12,000.
A lot of work, a huge amount of time and effort, but very satisfying.
648251
Follow Up By: Nomadic Navara - Saturday, Jul 12, 2025 at 11:00
"New hubs with electric braking, new tyres, new pop-top skirt."
You may not have to renew the hubs, but adding electric brakes - yes. In saying add electric brakes, you can add the electric backing plates and retain the over-ride brakes, just connect the existing brake cables to the
parking brake mechanism of the new brakes. This will retain the
heritage features of the old van. And before I get jumped on by the armchair experts, the dual systems were installed by van manufacturers during the time that manufacturers were going over to fitting electric brakes to all vans. This was done to attract buyers who already towing vans with override brakes to purchase vans and use them without first fitting a brake controller.
As for replacing the skirt, the van does not have a skirt hanging off the pop-top. It has folding solid walls that fill the void when the top is raised. The solid walls are a much better arrangement than thin curtains. You would have to do considerable work to add the aluminium tracks to secure the curtains, and you would destroy the
heritage value of the van.
929469
Reply By: Nomadic Navara - Saturday, Jul 12, 2025 at 11:22
You will have problems if you attempt to radically modernise the interior. I would thoroughly advise you to keep as much of the
heritage value of the van as you can. If you decide to sell the van in the future, vintage car owners are frequently looking for a
heritage van to tow behind their cars to vintage car rallies. this will ensure you have a ready market waiting for your van.
The side walls of your van, I suspect, will be of foam panel construction. I do not know of any vans of that age that
Franklin used framed construction in the side walls. This means that the interior plywood is firmly glued to the foam insulation in the walls, which will make it extremely interesting if you attempt to replace it. Also, the construction of the fixed interior furniture is very lightweight. If you attempt to replace it with furniture with solid construction, you will seriously increase the weight of the van. The axle/wheel assemblies on those old vans is very lightweight so if you add new furniture that does not use the same construction methods, you could have to replace the whole axle assembly.
Changing the interior lighting to LED lights that match the old lighting will not change the
heritage value of the van much, as will be replacing the external running lights with LED assemblies. You can still get new glass covers to replace the one on the outside annex light that appears to be missing, You can get LED assemblies to insert in that light.
When you learn to live with the dark colours in the van you will enjoy your
heritage van.
648253
Follow Up By: Richard M29 - Saturday, Jul 12, 2025 at 11:48
Change the lino, change the curtains and bedding repair leaks if required, fit led lights, fit battery, leave the brakes as over ride, and leave it in original condition, like some one said they are highly sort after in original cond., also if you really want to strip it completely down, go to the Caravanersforum.com find the Renovation thread, and their are thousands of posts on there how to do it, but unless you are extremely handy with the tools, you will most likely wreck it, and it will end up worthless
929470
Follow Up By: Member - Bigfish - Saturday, Jul 12, 2025 at 15:31
I definitely would put electric brakes on rather than the over ride ones. 10 times more affective , adjustable to suit conditions and a lot better at stopping the van safely with progressive braking that can be set by you, using the controller, to allow for dirt/dry or wet roads.. I don't believe any manufacturer puts over ride brakes on a van any more (could be wrong).
929477
Reply By: RMD - Saturday, Jul 12, 2025 at 17:11
Hello StephJane.
Apart from what others have mentioned, If maintaining the LOOK is required then perhaps my suggestions are not what you want, BUT, for ease of wheel changing especially in a challenging situation , while renovating, I would cut a wheel arch to access the wheels. At present you will have to jack it quite high to full spring droop and then fight to get the wheel off.
Also, if possible, fit larger than 13" rims if it has those, because of tyre /load ability and speed rating. A larger modern tyre will cater for highway speeds much better and carry the load with a greater degree of safety.
While in QLD travelling south, a Landscruiser with an older van overtook my 95 khm at an elevated rate. I commented, we will see him soon. 15km later, One of the thin overloaded 13" tyres gave up, threw in the towel and disintegrated. I changed it for them and said, if you travel at high speed with those tyres, they will fail. He blew two in total before learning the lesson. Tyre trouble is NOT what you want if spending time on any van.
648257
Reply By: Peter_n_Margaret - Saturday, Jul 12, 2025 at 18:39
What is the objective here?
1. A "period restoration"?
2. To get a van to use and enjoy at a budget cost?
3. To provide you with a job to get you off the street?
If the answer is 1, go for it, but it will take 3 times as long and cost 3 times as much as you estimate now.
If the answer is 2, or 3, I suggest you sell it because 2 is unlikely to be achievable and starting from scratch will give you a better result.
Motorhome home builder.
OKA196
648259
Reply By: Member - Gordon B5 - Saturday, Jul 12, 2025 at 21:37
Try
vintagecaravans.proboards.com
some very knowledgeable people on there with regard to older caravans.
It isn’t a very busy site & runs on old technology but if you have questions someone will get back eventually. You may even find others that have restored the same van as yours. There are threads for most vans produced in Australia.
648260
Follow Up By: Member - nick boab - Saturday, Jul 12, 2025 at 22:10
Jack & megan youtube
There are a heap of these videos on YouTube which you have mostly like seen & get some good ideas from .
good luck
929483
Reply By: Member - McLaren3030 - Sunday, Jul 13, 2025 at 07:19
Hi Stephjane,
If you are thinking of putting Solar Panels on the roof, be aware that this will add a significant amount of weight to the roof. It will most likely mean that your current scissor lift may not be strong enough to both lift the roof, and hold it in the raised position.
648261
Follow Up By: Member - Bigfish - Sunday, Jul 13, 2025 at 19:55
There are some very light panels out there that are reasonably light. For example Kickass have one ..KickAss 12V 280W Ultra Slim Fixed Glass Solar Panel...16kg
929491
Follow Up By: Member - McLaren3030 - Monday, Jul 14, 2025 at 08:36
Yes Bigfish,
And that might just be enough to make both lifting the roof more difficult, and having it not stay up once it is lifted.
It may very
well be OK for the first few times the roof is lifted, however, this van and it’s scissor lift is nearly 50 years old, and likely to have some wear in the mechanism. I am merely advising the OP that any extra weight on the roof may compromise the scissor lift.
929498
